R50/53 Drivers side reservoir
Headlights (if equiped with washers) only activate every 3rd time or so when the lights are on and the front window is washed.....
Rear window...try a neededle or pin to clean the sprayer....then use it semi-regularly to keep it clean.
It can be a permant clog if left too long...and allowed to corode.
Tyere is a wealth of info in the users manual....also online in a pdf.
if you remove the rear hatch cover and the hose into the wiper motor you can test the operation of it, if it is coming out of the hose all nasty you can try to clear the lines. if it comes out of the hose clean you can remove the nozzle end and push the brass like straw out of the back of the motor to soak in a cleaning solution or use compressed air
Alright thank you I have another question I discovered that If you hold down the unlock button on your key you can roll down the windows and open the sunroof is there a way to roll them back up with the key as well?
Here is a diagram of the rear window parts:
You can see the motor is part of the fixture and the little spray tube nozzle that extends.
Like they said above you can try to clean that part out. #1 in diagram
http://www.ecstuning.com/Search/67636932013/ES184448
Usually when they keep leaking out the back and it dips : the non return valve is the problem. #11 in diagram
http://www.ecstuning.com/Search/61688229249/ES170718/
There is a module you can buy from KP Technologies that will allow you to close up with the remote, but only if you have the OEM alarm.
RACEnSK8
Aug 31, 2015 01:08 PM
Russter500
Aug 26, 2015 12:11 PM
