R50/53 At what point should I upgrade my clutch?
Old Mar 10, 2013 | 05:49 PM
SniperDetailing's Avatar
SniperDetailing
Hey guys.
I'm planning on installing a new Crower NS1 cam, Megan Racing header, 550cc injectors, and a GIAC tune in addition to a custom catback, Alta intake and a 16% pulley and I'm wondering at what point the stock clutch starts to not be able to handle the power?
Old Mar 10, 2013 | 05:56 PM
Miniman s's Avatar
Miniman s
It doesn't seem like you need an upgrade unless you do a lot of racing or are just hard on your clutch.
Old Mar 10, 2013 | 06:10 PM
Braminator's Avatar
Braminator
At the point it starts to slip and fail. Its that simple. Also as you will find out if you replace the clutch go back to a stock clutch and avoid lots of issues.
Old Mar 10, 2013 | 06:12 PM
SniperDetailing
That would be a good answer if the question was "at what point do I replace my clutch?", but obviously when it starts slipping a new one needs to go in. What I'm asking is when the stock one does give up the ghost should I go for an aftermarket one with more holding power or will the stock clutch be sufficient?
The IB/W in my sig is long gone btw so my current one is running a stock clutch if you were confused by that.
Old Mar 10, 2013 | 06:15 PM
Miniman s's Avatar
Miniman s
In my experience the stock clutch is good up until about 250hp or so so not until you do a sprintex or big valve head you shouldn't have an issue.
Old Mar 10, 2013 | 06:18 PM
Braminator's Avatar
Braminator
Not confused. There is no need to think about a clutch failing with any mods until it does.
Old Mar 10, 2013 | 06:19 PM
SniperDetailing
Not confused. There is not need to think about a clutch failing with any mods until it does.
So with the same train of thought you don't think about changing your oil until you have a rod bearing fail on you?
Old Mar 10, 2013 | 06:22 PM
Braminator's Avatar
Braminator
Seriously. Think about it and do a search on all the clutch failures under the assumption they needed the high performance aftermarkert clutch that fails within 10k or so miles and yet with some heavily modded cars like MINIman S stated the stock clutch holds up better then most aftermarket ones. Do a search and see for yourself.
Old Mar 10, 2013 | 06:23 PM
Braminator's Avatar
Braminator
And this would be caused by lack of oil, not by not changing it.
Old Mar 10, 2013 | 06:27 PM
SniperDetailing
This is precisely the reason I asked if I should stick with a stock clutch or not. Had I possessed the information that the stock clutch could handle the power I will be putting down I wouldn't have asked the question. At no point did I say "I am going with an aftermarket clutch because of x reasons". You are arguing against someone who has not made a point to argue over. I know the aftermarket clutches usually fail quicker than the stock clutch, but if the stock clutch can't handle the power from the beginning an aftermarket clutch would be the only way to go regardless of it fails faster than a stock clutch because the stock clutch would just slip with that amount of power.
Old Mar 10, 2013 | 06:41 PM
SniperDetailing
oil consumption happens, man
Old Mar 10, 2013 | 06:50 PM
Braminator's Avatar
Braminator
I believe that is to be considered lack of oil.
Old Mar 10, 2013 | 06:51 PM
SniperDetailing
caused by oil consumption, assuming your car doesn't leak
Old Mar 10, 2013 | 06:53 PM
Braminator's Avatar
Braminator
LMAO you are the man.
Old Mar 10, 2013 | 06:54 PM
SniperDetailing
Why did you try to start arguing with me? I don't understand.
Old Mar 10, 2013 | 06:59 PM
Braminator's Avatar
Braminator
I simply gave my opinion and you thought I was confused. Then you came back with this
I simply gave you my opinion based off of this
Hey guys.
So I gave my opinion that you should not worry until it slips and from your question your mods should not cause any issues with the stock clutch. Thats all I was saying. So you began the arguement. But I am sorry it happened.
Old Mar 10, 2013 | 07:04 PM
SniperDetailing
The reason I came back at you with the oil comment was because not worrying until it slips doesn't make sense to me. What if the clutch is just slipping because it already has 88K miles on it and the extra power was the tipping point in making it slip? How would I know if the miles+extra mods were the cause or if a stock clutch just can't handle it? Then how would I know what to replace with?
All you had to say was "your mods should not cause any issues with the stock clutch", but you never did.
Old Mar 11, 2013 | 11:05 AM
scoopieb's Avatar
scoopieb
I agree, Bram you are coming across as combative, at least to me.
I put a new BVH, cam, and injectors in a few months ago and shortly thereafter my stock clutch with 60K started slipping. At first, I figured it was the additional power and/or older clutch. However, once I got into it, it turned out to be a leaking tranny seal which I replaced along with a new clutch. I ended up getting an OS Giken but after some research found out up to 250HP the stock should be fine. In fact Colin, has over 270HP and the stock is working for him. Good luck!
marendt428
Nov 14, 2015 10:03 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Zettinger
Aug 25, 2015 04:04 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
marendt428
Aug 8, 2015 04:44 AM
