R50/53 Trunk Power Outlet?
Old Feb 2, 2013 | 05:17 PM
chdrake2002's Avatar
chdrake2002
Trunk Power Outlet?
I bought an 02 MCS. In the trunk area is a hole on the left side and a wire connection. So I went to the Mini dealer today and they sold me an illuminated ring and 12v socket that is supposed to go there according to their diagram. However, the illuminated ring will not fit into the hole without some modifications, but the 12v socket does connect and works correctly. Can anybody tell me how this part is supposes to fit into the hole? I'm just looking to put the car back into the original condition. I have searched the net for info, but no luck.
Thanks!
Old Feb 2, 2013 | 05:59 PM
dannyhavok's Avatar
dannyhavok
I had a broken orange ring below the toggle switch bank, so I swapped in the one from the trunk... I had the same experience, it just does not fit. I ended up using a thin screwdriver to pry the hole a little wider so I could pop the assembly in at an angle. I'm sure this isn't the ideal solution, but it's in there now.
Old Feb 2, 2013 | 06:06 PM
tremperj's Avatar
tremperj
Could be worse. You could be like me– 2003 was the only year that they removed the trunk 12V outlet.
Old Feb 2, 2013 | 06:41 PM
chdrake2002
Thanks for the idea. I took a razor knife and shaved down the "ears" on the illuminated ring. I think the "ears" are for the bulb, which doesn't appear to be used in the trunk. Tomorrow I'll see if it will fit into the hole.
Old Feb 2, 2013 | 07:04 PM
rkw's Avatar
rkw
That's correct. There is no wiring for the bulb in the trunk power outlet.
The bulb mount (items 5 and 6) is separate from the socket body.
Old Feb 3, 2013 | 01:35 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
I retro-fitted trunk (boot to me) power in my 03 R50. I use it to power the sub or lights or air pump or car fridge, depending.
Old Feb 3, 2013 | 04:57 AM
chuckee98's Avatar
chuckee98
Put the ring in the hole first, then push the socket into the ring. That's how I did it.
Old Feb 3, 2013 | 05:30 AM
chdrake2002
Unfortunately, I put the ring and socket together to see how they fit thinking I could get them back apart... They don't seem to want to come apart now...
Old Feb 3, 2013 | 06:22 AM
ViperNL's Avatar
ViperNL
My 06 R53 does not have one either.
Old Feb 3, 2013 | 06:28 AM
chdrake2002
Thanks guys for your help!
I was able to fit the factory illuminated ring (after shaving a bit of the ears off) and socket into the factory hole and plug into the factory wiring harness connection. Even though I had snapped the two pieces together already it just popped right into the hole with no difficulty. Of course the illuminated ring is not lit and is not supposed to be. Also, the fuse for this (12 volt power outlet) factory harness connection is F31 located at the drivers foot rest. I hope this info helps someone else in the future.
Thanks again!
carid
Dec 28, 2025 04:11 AM
rbarakat
Oct 3, 2015 11:08 PM
BucksCountyR57
R57 :: Cabrio Talk (2009+)
Sep 21, 2015 05:42 AM
David Eric Rosenberg
Sep 10, 2015 12:34 PM
Ntety
Sep 2, 2015 08:39 PM
