R50/53 Question about the on-board computer...
Old Mar 29, 2004 | 09:12 PM
CinniMini's Avatar
CinniMini
Do I want to add this when I order my MC? What exactly does it do? TIA!
Cindy
Old Mar 29, 2004 | 09:16 PM
Yucca Patrol's Avatar
Yucca Patrol
It gives you the following readouts:
Outside temperature
average fuel consumption
average speed
estimated miles to empty
_________________
SE Regional, BAMA Club Moderator: PM me
Old Mar 29, 2004 | 09:22 PM
Teampajn's Avatar
Teampajn
I wouldn't say it is necessary, just another toy to play with. I do like having the outside temp handy though. The estimated miles til empty is nice during trips also. I've heard the average M.P.G. is incorrect, and haven't tested mine to see if it's true or not. I haven't found a use for the average M.P.H. yet though.
Old Mar 29, 2004 | 09:24 PM
C4's Avatar
C4
You also get the electronic speed readout (Regardless of whether you order the trip computer or not).
I have it in my '04 MCS and use it quite often.
Old Mar 30, 2004 | 02:09 AM
ecl3x's Avatar
ecl3x
i wish mini would incorporated "light out" warning with the computer similar to the 3-series
Old Mar 30, 2004 | 02:18 AM
jsun's Avatar
jsun
I use the "Range" (aka miles to go until you REALLY run out of gas) function quite often. As for some reason I just can't tell from looking at the analog gas gauge how much gas is left. So, I always find the red light on...and then go to Range on the computer to see how quickly I need to find gas. It's mostly correct, btw. Although once I drove about 60 miles (and the Range read -4 or something obviously wrong) before I found gas. That was close...
Also, if you don't get the computer, you won't be able to post "How come my MINI beeped at me?" in the fall when the temperature falls below 37 degrees.
And regarding the temperature warning, has anyone ever wondered why the thing's set up so that it ONLY beeps when you cross 37 degrees (going either up or down)? If the temp is already less than 37 when you start the car, no beep. Did someone convince the MINI engineers that ice ONLY forms at 37 degrees and not when it's colder?
Old Mar 30, 2004 | 03:25 AM
d-mini-ero's Avatar
d-mini-ero
I find myself contantly... switching thru the different readings...
It's become standard fare for me and a habit of sorts.
I particularly enjoy the "miles left " b4 you run outa gas ...reading
Old Mar 30, 2004 | 03:39 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
I use the average speed function of my OBC to set my cruise control speed. I find the speedo is not very accurate. Depressing the button once resets the speed and a second later gives you an accurate LED display of how fast you’re going. I find my speedo can be off as much as 5 MPH. That’s the difference between getting to work on time or being late because I was stopped and given a ticket. On the highway 5 MPH may not mean much, but traveling 30 and 40 MPH roads, 5 MPH can get you a ticket easily in my area.
Old Mar 30, 2004 | 09:15 AM
MINI_Dreamer's Avatar
MINI_Dreamer
>>Cindy
Cindy -- I'm not sure what you're ordering with your MC, but the OBC comes with the premium package, which if you're getting the sunroof and MFSW is a good deal.
MINI_Dreamer (not for too much longer )
Old Mar 30, 2004 | 12:12 PM
C4's Avatar
C4
>>>>Cindy
You can also get OBC as a standalone option for $200. I have OBC and Sports MFSW steering wheel, but did not get the complete Premium Package (Sunroof and auto A/C).
Old Mar 30, 2004 | 12:41 PM
Johnna's Avatar
Johnna
I don't have the OBC and the little window shows outside temperature. How do you get it to show an electronic speed readout?
Old Mar 30, 2004 | 12:47 PM
C4's Avatar
C4
If you have a 2004 MC or MCS with or without OBC, LCD Speed readout is available in the tach by pressing the button located on top of the left side turn signal/lights stalk.
LCD speed readout is not available in 2002-2003 MINIs.
Old Mar 30, 2004 | 01:43 PM
fms's Avatar
fms
I like what happens when I fill up after some leadfooted city driving, w/ a low average mpg on the computer. The miles per fuel remaining will tell me that I can go 260-285 miles on a tank. Then I'll go out on the road and drive at a steady speed (70-75) for 15 minutes or so. While I'm driving, the miles per fuel remaining will climb, sometimes up to 400 miles, as the car refigures.
Old Mar 30, 2004 | 01:59 PM
asodestrom's Avatar
asodestrom
Get it. It's not a lot of money, but ifs fun to use. Gives you something to do to keep yourself occupied on long freeway trips.
Old Mar 30, 2004 | 03:27 PM
H&J's Avatar
H&J
The trip computer comes with our package (MCS due in May), but it doesn't impress me. I like the idea of using it as a back up for an analog speedo that might be less than accurate (which would be a pitty). As for countdown to empty feature, I've had good luck in our CRV pushing the clear-odo button manually as soon as the "reserve tank" light comes on... knowing we have aprox 2 gallons left at that time, and aprox. 25-28 mpg, I have gone to 50 miles being relaxed until I get to an out of the way station on the road. Perhaps the computer will be accurate enough to do the same... we'll see.
Old Mar 30, 2004 | 06:22 PM
CinniMini's Avatar
CinniMini
Thanks for all the info everyone. I'm not getting any of the packages because there are certain thing I really don't want in them.... especially the sunroof.
Guess I'll have to take a closer look at the OBC next time I test drive one.
Cindy
Old Mar 31, 2004 | 06:00 AM
holdenontoit's Avatar
holdenontoit
Old Mar 31, 2004 | 06:10 AM
greatgro's Avatar
greatgro
I believe the new MINIs also have tell the current mpg and not just the average. I wish I had that feature! And also the current speed.
Old Mar 31, 2004 | 06:14 AM
C4's Avatar
C4
You are correct. Current or "real time" MPG readout is also a new prompt added to the '04 MINIs.
Old Mar 31, 2004 | 06:49 AM
JuanPacoLopez's Avatar
JuanPacoLopez
It is also almost entirely useless :smile:
The ONLY use I can see for it is on a nice long highway trip where you go at a constant speed for hours. Then you could get a good feel for your mileage as you went along and estimate gas costs or something?
Other than that it jumps up to 99mpg when you slow to a stop and about 9-11mpg when you first take off. Getting an accurate measurement from this in city driving is completely impossible :smile:
donniedarko
Oct 21, 2015 01:15 PM
rob&JCW
Sep 10, 2015 12:06 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
mimaal
Sep 4, 2015 09:09 AM
