R50/53 GreekDrifter's R53
Old Dec 17, 2013 | 09:29 PM
  #351
GreekDrifter91's Avatar
GreekDrifter91
Originally Posted by Stoker
Greece!!.. I gotta go back!! whats the name of that town?
Thats in Parga, Greece
Old Dec 19, 2013 | 12:38 PM
  #352
GreekDrifter91
Great Newwsss!!!! its not a dacia sandero but the injectors work! like i suspected it was user error like the plugs not being pluged in all the way. enginen fired right up and reved fine. but dyno says top end feels better and low end feels a bit worse. but under WOT
i just reset the ecu via the gauges and using the bev tech software, after the test drive. so im at my bros house on the way home and through out the week we will see how the ecu adapts aand make it feel better.
Old Dec 19, 2013 | 02:21 PM
  #353
Tab32's Avatar
Tab32
Me gusta
Old Dec 19, 2013 | 03:13 PM
  #354
GreekDrifter91
just as i though clearing any adaptions the ecu had made the car feel a whole lot better across the rev range. now off to get a header and cat-back, stay tuned.........
Old Dec 19, 2013 | 04:24 PM
  #355
Stoker's Avatar
Stoker
nice!!
Old Dec 22, 2013 | 01:49 PM
  #356
GreekDrifter91
thought i would make an update. car is running great. feels better now than it did before especially after clearing the ecu.
Also i was looking at my excel sheet of mods and future mods there isnt much left on the list...
Engine: 9/24 items left
- ATI super Damper +2%
- MSD coil pack
- Wires
- silicone intake tube
- GP intercooler
- GP Diverter.
- ALTA cat-back
- M2 Header
- tune.
Suspension: 3/12 items left
- Rear Sway Bar
- adjustable drop links
- adjustable control arms
Brakes: 3/7 items left
- EBC Ultimax blackdash slotted rotors front
- EBC Ultimax blackdash slotted rotors rear
- brake pads that can handle more heat.(something more than ebc green stuff)
after all of this it will just be little things hear and there, cosmetic stuff basically.
Old Dec 23, 2013 | 10:20 AM
  #357
Stoker's Avatar
Stoker
Got a list of the mods you've done? all in one place i mean.
Old Dec 23, 2013 | 06:30 PM
  #358
GreekDrifter91
Yea i have an excel spread sheet of everything i wanted to do and running total of what it costs
one sec let me go copy paste everything.
Old Dec 23, 2013 | 06:34 PM
  #359
GreekDrifter91
left a lot out but here is a summed up version. By the time im done i will have spent a little more than the amount of money i bought the car for in mods. and it will be a better MINI for it!!!
Engine
- 17% sc reduction pulley
- Spark Plugs
- DDMworks CAI
- NAPA 060532 Belt For 17%
- Detroit Tuned Bypass Valve
- Genesis 380cc injectors
- ALTA Intercooler Boots
- Craven Speed Dipstick
- Used Transmission
- Bavarian Technic Diagnostic
- Idler Pulley
- Tensioner Stop
- Rebuilt Supercharger
Suspension
- Swift Springs
- Koni Yellows
- Craven Speed STD's
- Kosei K1 TS 17x7 15lbs
- Summer tires 215/45-R17
- Metal Hub-centric rings
- Poly Front Control Arm Bushing
- Poly Steering Rack Bushing
- Poly Gear Box Inserts
- Poly Engine Mount Inserts
- Lug Bolt Caps
- Ireland Engineering Fixed Camber plates
Brakes
- Brake Caliper stiffening kit*
- EBC Green Stuff pads
- ATE Super Blue Brake Fluid
- Stainless Steel With Teflon Liner Brake lines
Other
- DIY Air Plate Diverter
- Oil Catch Can
- Auxiliary Audio Input Interface
- Fuel Filter
-....... list goes on forever
Old Dec 24, 2013 | 10:25 AM
  #360
Stoker's Avatar
Stoker
Your a braver man that me.. i absolutely don't wanna know what I've spent ")
Old Dec 24, 2013 | 10:36 AM
  #361
Stoker's Avatar
Stoker
How do you like the brake stiffeners?
Old Dec 24, 2013 | 09:17 PM
  #362
GreekDrifter91
eeeehhh im not really sure you could feel a difference. steel lines and new fluid are great though!
Old Jan 11, 2014 | 11:14 AM
  #363
GreekDrifter91
Some tools came in the other day.... just a few more things off my mechanics check list lol..... also my two oxygen sensors should be in today as well. i hope i will be able to install them tomorrow.
and because of this weird weather i had to apply a liberal amount of dielectric grease to my injector plugs because of moister problems. i was getting misfires and injector signal errors and it would ultimately shut down one or two cylinders.
Old Jan 13, 2014 | 08:02 PM
  #364
GreekDrifter91
O2 sensors came in... looks like i wont need them but only time will tell. i thing my lean issue came form cylinder misfires do to the connector to the injectors no making a good connection i slobbered them with dielectric grease and everything works perfect now i rest the ecu and all the adaptation and i'm only at 70 miles sense then so probably around 100-150 it will tell me if something is up...... if no problems i will just use them when i get my header and cat back so i don't have to take old o2's out and in again.
and i forgot to post this to got it for Christmas lol
Old Jan 16, 2014 | 10:12 PM
  #365
nismo4life's Avatar
nismo4life
Nice thread man. You trying to sell that FC? Because I'm trying to get rid of my LS400 drift car, would love a clean FC to replace it as a weekend car .
Old Jan 17, 2014 | 10:14 AM
  #366
GreekDrifter91
No, Never!
car is going to stay with me untill it has literally fallen apart and is not even possible to repair anymore. i love it way to much. sorry buddy. you wont belve how many offers i get for it dude. and i turn away all of them.
Old Jan 17, 2014 | 09:14 PM
  #367
GreekDrifter91
little update.... my need to revert to my stock injectors. i keep getting random misfires. not sure if my old ecu does not like using ev14 injectors or if maybe it doesn't like the spray pattern. i also noticed some kinks in the wires to the injector plugs so maybe the wire are internally damaged. ill have to look some more on tomorrow or Sunday. i know a tune would fix this if its just the injectors, but i need to wait till i get my header and cat back in to do a tune.
it could very well be these piece of sh*t adapters that came with it. im still waiting for a different style to come in. it looks like usps may have lost them. its been for ever and no tracking updates yet sense they left Huston.
Old Jan 24, 2014 | 12:55 PM
  #368
GreekDrifter91
New parts came in!
Megan racing/M2 header and a mini-cat o2 spacer....
im gonna need opinions on this but i feel like im gonna have to hork out ton of metal on the ports. they look super tiny and the the ledge between the port and the runners is at least 1/4" maybe more. i also do not know how big the ports are on the head so im not sure what to do here. but the gasket is going to need some modding as well the ports dont exactly line up too well. over all thought the welds look decent and thats about it the stainless steel looks alright but wont look like that for long because next step is cermic coating. oh and im gonna get another bung welded in so that i can put in a wide band o2... also flanges are warped so gonna need to straight those out.
Old Jan 24, 2014 | 01:06 PM
  #369
SniperDetailing's Avatar
SniperDetailing
Make sure you bolt that header up to your head before you do any coating. I ordered one off ebay that looks exactly the same down to the o2 plug-bolt and there were 2 or 3 manifold bolts that just wouldn't line-up at all
Old Jan 24, 2014 | 07:55 PM
  #370
GreekDrifter91
Greaaattttt.... i knew these were cheap quality but i mean at least get the bolt holes right..
god thats gonna be a lot of work... but ill make it happen.... im gonna grind down those ports and get them welded form the inside too, while im at it. same with the two bolt flanges.
ill ask around in the megan header thread to see if anyone else has had that issue.
Old Jan 24, 2014 | 09:55 PM
  #371
miniblucabrio's Avatar
miniblucabrio
Looks like you might have had better luck with an OBX header. Mine bolted right up. Ports were good the flanges were flat and even. Only thing is it doesn't have a flex section to it.
Old Jan 24, 2014 | 10:49 PM
  #372
GreekDrifter91
i just ordered a oem gasket and im gonna use that to see how well the ports line up as well as the bolt holes.
id rather have a 4-1 header with a flex pipe than a 4-2-1 with a ball joint.
plus i would rather buy a 200 dollar header put some work into it than buy a 1000 header and get the same results.
Old Feb 1, 2014 | 09:49 AM
  #373
GreekDrifter91
so got some gaskets in gonna see how well the bolt holes line up... intersting to see two of the holes are slotted.
also i have always been curios... are the manfold gaskets one one? are can thy go either way?
raised edge facing head? or raised edge facing manifold?
Old Feb 1, 2014 | 09:31 PM
  #374
Stoker's Avatar
Stoker
"raised edge facing head? or raised edge facing manifold?"
That's what i asked Steve, he said it didn't matter cause they get crushed..
I put the raised edges "facing" the manifold, made more sense…
He showed me a trick, if you have a couple of ten mm bolts cut the head's off and use them in the two outermost bolt holes to align/hold the gasket in place, while your putting on the header. made life very easy since, the header is an awkward fit..
Old Feb 1, 2014 | 10:56 PM
  #375
GreekDrifter91
cool, i have never known if there was a "right" way i always just slapped them on.
