R50/53 Radiator Fan Problems
Old Jun 21, 2012 | 01:32 PM
LIGHTINMCQUEEN's Avatar
LIGHTINMCQUEEN
I have a 2004 Cooper S with 80,000 miles I bought used. The air compressor stopped working right before the winter 2011. I didn't replace it until about 3 weeks ago because summer was getting here in Alabama. The compressor was replaced by a local shop and finally blows COLD air. However, the radiator fan will come on for a few seconds and shut off, come back on for a few seconds and shut off. Will continue this as long as the air compressor is on. There really isn't any regular intervals to it. Mostly happens or seems to happen when at idle. I can't for the life of me remember if it did this before since I haven't had air for a while. Can someone give me any advise or suggestions if this normal. Thanks.
Old Jun 21, 2012 | 02:35 PM
autoxjohn's Avatar
autoxjohn
Start the car. Turn on the AC. Go watch the fan. If it's not staying on consistently (i.e. it's cycling) then your low-speed fan resistor is dead. Tons of info here on the forum.
You can replace the resistor for $55-ish, or replace the whole fan for $75-ish.
Old Jun 21, 2012 | 04:03 PM
LIGHTINMCQUEEN
It is cycling but it seems to frequent of a cycle. It will come on for 2-3 seconds and turn off and than come back on for the same amount of time. I just couldn't remember since it was so long ago that I had the air condition on. Thanks
Old Jun 21, 2012 | 04:04 PM
autoxjohn's Avatar
autoxjohn
If it's cycling at all, then your toast.
Old Jun 21, 2012 | 04:06 PM
LIGHTINMCQUEEN
Toast as needing a new fan, correct?
Old Jun 21, 2012 | 04:07 PM
autoxjohn's Avatar
autoxjohn
Toast as in - either the fan or relay probably need to be replaced, yep!
Old Jun 21, 2012 | 04:08 PM
LIGHTINMCQUEEN
Thanks again for the help.
Old Jun 21, 2012 | 04:10 PM
autoxjohn's Avatar
autoxjohn
Here are your options:
http://www.detroittuned.com/shop/?productID=530
Or get a new fan. I got mine from RockAuto.com - cheap enough, and not too bad to replace yourself if you're handy.
alistaircookie
Oct 8, 2015 10:52 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Manny_cooper
Sep 10, 2015 11:09 AM
David.R53
Sep 1, 2015 06:51 PM
jesterofatlas
Sep 1, 2015 11:26 AM
