R50/53 rear fog lite
Old May 1, 2012 | 02:14 PM
trashmanbob's Avatar
trashmanbob
rear fog lite
I found the plug in the back for the rear lite, does that mean that the car is wired all the way to the switch and will it lite up when I turn on ?
Bob
Old May 1, 2012 | 02:22 PM
Eric_Rowland's Avatar
Eric_Rowland
No. The wiring is there, but the BCM still needs to be programmed to let it know the rear fog is there (in addition to adding a switch bank with the correct toggle.)
Old May 1, 2012 | 02:24 PM
Capt_bj's Avatar
Capt_bj
depends on a few things - the rear for wasn't even available in the US cars in the beginning. Buyers kept begging for it an eventually it was made available.
do you have a switch already?
what year and model?
there's been a lot of threads about this, did you try the search?
Old May 1, 2012 | 03:26 PM
MY4thMINI's Avatar
MY4thMINI
Love my rear foggers
Drove to work this morning in heavy fogg. Used both front and rear foggs
Old May 1, 2012 | 07:10 PM
trashmanbob
rear fog
2005 MCS Made 11/04
yes I know it needs to be programed, but all the wiring there ??????????
Old Jun 15, 2012 | 06:21 AM
DailyDrivenMini's Avatar
DailyDrivenMini
Any write up available? Thanks.
Old Jun 15, 2012 | 09:07 AM
rkw's Avatar
rkw
Yes. No additional wiring is needed.
I've done the rear fog retrofit on mine. Instructions are here: https://www.northamericanmotoring.co...t_Retrofit.pdf
Old Nov 2, 2012 | 10:35 PM
COR BLMY's Avatar
COR BLMY
Some info ...
Looking into adding the fog I discovered a couple of things.
Understand the coding is needed (my son has the cable and program ... so easy)
I have 3 or 4 switch banks (usually used to add a dummy )
So I opened up the switches and IC board.
Where I found that all the connections were on the IC board .
The only thing missing was the LED for the illuminated switch.
So I removed one of the panel illumination LEDs (there are 6) and added it to the board where the LED needed to be for the rear fog.
I dabbed a drop of red paint on it .
all buttoned up / long story short .
the rear fog works and has an orange-ish glow to it .
Old Nov 16, 2012 | 06:23 PM
JumpingJackFlash's Avatar
JumpingJackFlash
After alot of research, I ordered the correct parts to get the rear fog light installed in my '06 MCS. The '02-'04 models don't need a separate rear fog light installed, as the top lights in the factory tail light housings are what light up. However, I had to order the rear fog to go where the reverse light used to be. Now all I have to do is go to the dealership to get the function programmed into the ECU.
Here are the two part numbers needed:
Rear fog switch bank, ALL switches, DSC: 61 31 6 917 993 (61316917993)
Rear fog light housing, red: 63 24 7 166 015 (63247166015)
Here are some pictures of the parts ordered:
You can order the parts from DDM tuning:
http://www.ddmtuning.com/Products/BMW-61316917993SWITCH-UNIT-CENTER-CONSOLE613010 (DDM part 613010)
http://www.ddmtuning.com/Products/BMW-63247166015REAR-FOG-LIGHT631410 (DDM part 631410)
A couple of notes. First, DDM tuning has the switch bank OEM part number wrong. The 5th digit is wrong; 61 31 9 917 993 (61319917993) is NOT correct. Second, the rear fog light housing part number I stated earlier is correct. However, the actual part I received has a different 4th digit; it shows 63 21 7 166 015 (63217166015).
P.S. - I stated the part numbers two different ways to make each a searchable term in the forum.
Old Mar 25, 2013 | 12:04 AM
MikeysM3's Avatar
MikeysM3
I am having a hard time finding the full bank of switches. I want to do the rear fogs. Anyone can point me in the right directions?
Old Mar 25, 2013 | 07:05 AM
noreen99's Avatar
noreen99
http://www.waymotorworks.com/rear-fo...tch-panel.html
Ordered mine from above
Old Mar 25, 2013 | 07:28 AM
tremperj's Avatar
tremperj
Or, hound ebay for months and snag one for $25 like I did. Depends on your level of patience. Truthfully, I was right at the point that I was about to order one new.
Old Mar 25, 2013 | 07:42 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We can get you one, but you have to call and order with your options so we get the right one for you as there is like 3 different choices.
Old Mar 25, 2013 | 07:21 PM
MikeysM3's Avatar
MikeysM3
Yup spoke to you guys on the phone.. Thanks for finding me that switch panel! Can't wait to get it and install my rear fogs.
Dec 23, 2015 10:36 AM
I_drive_slow
Aug 18, 2015 10:47 AM
Powershift
Aug 16, 2015 05:14 PM
