R50/53 Awwww Yeah: Dropped on H&R's
Old Oct 15, 2002 | 06:35 PM
dave's Avatar
dave
pug poo picker-upper
Today I got the H&R Springs for the Cooper S series 2 suspension installed.
Thanks to Helix Minisports
Measurements to bottom of plastic wheel molding
Front
Before: 25.25"
After: 24.5"
Drop: 0.75"
Rear
Before: 25.5"
After: 24.5"
Drop: 1.0"
I'll post if there is any additional sag in the next couple weeks.
Old Oct 15, 2002 | 06:38 PM
cooper44's Avatar
cooper44
sweet, so sweet! did you change the struts/shocks as well?
Old Oct 15, 2002 | 06:53 PM
Mini-Matt's Avatar
Mini-Matt
dave - how has the ride changed? did you have to make any other adjustments to the suspension?
Old Oct 15, 2002 | 07:00 PM
ficcion's Avatar
ficcion
Nice...Looks like you got 17"s all over again.
Those 16" fill the wheel well nicely. I'll be interested to take a spin with you to "feel" the difference in set ups.
Old Oct 15, 2002 | 07:58 PM
greatgro's Avatar
greatgro
Dave - your 17" looked a lot better...
Old Oct 15, 2002 | 08:03 PM
2minis's Avatar
2minis
Dave.
R U rubbing at all with the 16s? I have the 215...17 Yokos
and ocassionaly rub. Love the tires though. Thanks for the
advice. Stick like glue once they are warm.
Mike
Old Oct 15, 2002 | 08:06 PM
Jay's Avatar
Jay
Looks great. Is there a significant improvement in handling?
Jay :smile:
Old Oct 15, 2002 | 08:27 PM
dave's Avatar
dave
No, to my knowledge there are no struts available yet for the series 2 suspension. There are full coilovers available, but no struts. So I'm running on the stock struts. Obviously not the preferred route, but it's the only route right now (other than the full coilovers).
Well, it's a little more firm. I believe BMP claims the H&R's are about 25% stiffer than the Sport Plus suspension on the Cooper S. That said, I'm running regular tires, so the ride is still more compliant than when I had the run-flats. :smile: No other adjustments have been made to the suspension. Just the springs.
Not a problem. I'll see you at the autocross on Sunday.
yeah, I miss those 17's, but they are heavy. The 16's and regular tires handle a lot better and cut a lot of rotating weight. Definitely helps accelleration and that Cooper S 1st gear bog to ditch the 17's and especially the run-flats.
I have not noticed any rubbing, but I only just drove the car home from getting the springs installed. And yes, I like my AVS ES100's too.
I'm going to preface this by noting my comment above about how I just drove this home from the install. That said, I think it will help the handling, but the proof will be on Sunday when ficcion, mferguson, and I go to the BMW CCA autocross.
One thing to note: The back end could really use camber plates. Regular tire rotation is going to be a must. The fronts wear on the outside, the rears on the inside, so at least the wear should even out.
Old Oct 15, 2002 | 08:31 PM
2minis's Avatar
2minis
Good luck Sunday and let 'em rip....
Old Oct 15, 2002 | 08:56 PM
trixander's Avatar
trixander
I must say that looks pretty nice. It doesn't look too low where it'll bottom out on every little dip.
trixander
Old Oct 15, 2002 | 10:00 PM
MINI-MadMan's Avatar
MINI-MadMan
Lookin' good there Dave. Nice balance of drop. You'll probably be putting that new skid plate to the test now, eh? 16's look better, imo. It would appear that the modding bug has claimed another victim. Keep it coming. Good on ya.
Cheers,
Old Oct 15, 2002 | 10:39 PM
Sfiveten's Avatar
Sfiveten
Looks Great Dave!!!
Old Oct 16, 2002 | 04:35 AM
wainair's Avatar
wainair
looking good! Let us know how the 20th goes!
Old Oct 16, 2002 | 04:44 AM
bangBANG!!!'s Avatar
bangBANG!!!
Nice set up!! Hey, how come i cant save your pics on my pc. it turns out to be in a weird format.
Old Oct 16, 2002 | 05:10 AM
Davbret's Avatar
Davbret
They save as a *.bmp (bitmap) file. Just save it and then open it in something like your windows paint program and then do a "save as" and select *.jpeg.
R
Old Oct 16, 2002 | 05:11 AM
Davbret's Avatar
Davbret
R
Old Oct 16, 2002 | 05:43 AM
dave's Avatar
dave
Try changing the file name and adding the .jpg extension. That should take care of it.
Old Oct 16, 2002 | 05:42 PM
dave's Avatar
dave
Here are some before and after pictures of the front and rear wheel gap.
Rear Before
Rear After: total drop 1.0"
Front Before
Front After: 0.75"
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
gar56
Nov 15, 2016 06:41 AM
Suspension Products
Oct 1, 2015 11:53 AM
aldito2
Sep 30, 2015 10:44 AM
gnhovis
Sep 28, 2015 10:56 AM
