R50/53 Is Cooper S track wider than standard Cooper?
because I drove my 02 MINI for 22 months and 26K miles without putting a ding on a wheel. I have had my Cooper S for 6 days and I twanged a curb at Wendy's drive through and tore up the left rear, then today, my wife was parking the S and hit a curb with the right front and tore up that wheel.
Somebody pleeeeze tell me the track is wider so I have something to blame this on.
Jeff
Jeff
actually, the MCS has a narrower track than the MC!!
(MC=57.7"/MCS=57.5"rear and MC=57.4"/MCS=57.2"front)
This is only because the wheels for the MCS have slightly
more positive offset than the wheels for the MC
(MC ET=45mm/MCS ET=50mm), and the track measures
from the middle of one wheel to the middle of the other.
I say it is Bush's fault!!!
I too have sinned, but can't even hint at having driven another car. Last Sunday I drove into my friendly Mini dealer's lot and bought myself a kerb. Thankfully it was quite low and rounded. Just did not see it in the middle of the ramp! No damage but quite a jar!
>>Do you now have 17" wheels? I have heard they are less protected by the tire than the 16" or 15" wheels?
>>This doesn't explain running into things, but could explain the damage.
>>emerika
Yes I now have 17's and I think you are right, the tires seem to almost be flush with the rim.
So what you are really saying is that I've been running into things alll along.
>>emerika
It's also a function of the lower sidewall profile of the 17 inch tires. If you look at the 15, 16 and 17 inch wheel/tire combos, they all have the same rolling diameter. There's just more rim, less tire.
So the bottom line is I have been running into things all along I was just protected by rubber. I wonder if they still make curb feelers?
I had 18" wheels on my last car. I've never hit as many curves in my life until those expense jewels showed up! FYI, if you ever scratch or dent a wheel you can get them repaired...it's cheaper than buying a new one.
I think you should just be more careful and drive slower when parking or driving in a drive thru etc. I've never curbed a wheel in any car I've ever driven, I just try and be as careful as I can.
Please dont say that or the rest of the sheep will follow
PelicanParts.com
Aug 4, 2015 02:45 PM
