R50/53 When did steering wheels go from two-spokes to three?
Old Nov 14, 2009 | 10:18 AM
blacter's Avatar
blacter
I'm trying to get a replacement steering wheel airbag for my '02 Mini, since the one in there now is dinged up and ugly. I ordered one, but what came is the airbag for a three-spoke wheel. I assumed the three-spoke was on later Minis, but now I wonder if Mini used the three-spoke on some models of the 1st gen cars.
Can one of you give me the scoop? Thanks.
Old Nov 14, 2009 | 10:44 AM
Crashton's Avatar
Crashton
I believe that started with the 2005 MINI builds. Not sure of the exact date the change was made.
Old Nov 14, 2009 | 12:12 PM
Alpha Motoring's Avatar
Alpha Motoring
02 to mid 04 was 2 spoke
on 04 it was a option for the 3 spoke but if you look closely the stitching pattern is a bit different on the 04 3 spoke
05-06 had 3 spoke
Old Nov 14, 2009 | 02:10 PM
DAVESTER's Avatar
DAVESTER
My 04 MCS has a build date of 03/2004 and came with a three spoke wheel. When I ordered in 02/2004, I had my choice between the two---
Old Nov 14, 2009 | 02:14 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
The two spokes also had different styles. Cars built in 2002 had a smooth two spoke, later on they had perforated leather, and others had bulges where you'd grip. I'm partial to the early early style I have, smooth leather with no bulges.
Old Nov 14, 2009 | 03:56 PM
blacter's Avatar
blacter
I assume the airbag stayed the same on all the two-spoke wheels. Is that correct?
Old Nov 14, 2009 | 08:33 PM
chaseabryant's Avatar
chaseabryant
You should take this little mishap as a sign that you should switch to a 3-spoke wheel! Easy swap, and you can finally honk your horn with the airbag cover!
-Chase
Old Nov 14, 2009 | 11:11 PM
Galactor's Avatar
Galactor
Does anyone know if the Mini warranty covers the buttons in the steering wheel? Or that is considered "normal wear"? The used MCS I'm getting has some of the steering wheel buttons shaded with lighter color. Not a big deal, but I guess if it's not covered I'll ask the dealer to lower the price.
Old Nov 14, 2009 | 11:20 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Yeah, it did.
-Chase
But then you'd loose the MFSW buttons on the back side of the wheel. This is the best placement.
Having the center for a horn is crazy to me. I need a precise button that I would deliberately press.
Old Nov 15, 2009 | 11:24 AM
blacter's Avatar
blacter
-Chase
Thanks, Chase. You got my curiosity aroused. What's involved in swapping the two-spoke to the three?
Old Nov 15, 2009 | 06:55 PM
blacter's Avatar
blacter
There's a three-spoke wheel on eBay now, but it has shifter paddles. Anyone know if those are easy to remove?
Old Nov 16, 2009 | 10:31 AM
jonnieoh's Avatar
jonnieoh
To go from a 2-spoke to a 3-spoke, you need to buy a la carte:
1.) the 3-spoke wheel, (which is just the wheel itself; nothing else)
2.) an airbag module for a 3-spoke wheel,
3.) the spoke cover plates, (this can be bare covers or the multi-function controls).
4.) wiring harness for any multi-function buttons, (if your car had them already)
Manny_cooper
Sep 10, 2015 11:09 AM
mdarreen
Sep 2, 2015 10:11 AM
trw92a
Aug 26, 2015 01:47 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
