R50/53 Airflow diagrams? how does the supercharger work?
let me start off by saying- i full understand how a supercharger and an engine work, and how they work together.
i'm looking for information specific to the mini though.
does anyone have any diagrams or information regarding the mini's setup, with detailed information on things like the BPV. (which i understand plays a large part in everything)
for what its worth, i started reading the "yo-yo chronicles"...
i just dont have it in me to read something starting back in 2004 to figure out how the BPV works and such.
i have that little 3000rpm hiccup, and from what i've read the DTBPV will fix it.
i kinda want to know WHY this is all happening and how.
Here is a quick MS paint diagram I went and did. The bypass valve works on a vacuum. When the throttle is closed it is held open by the vacuum bypassing (more like re-feeding) the supercharger. When the vacuum goes a away a spring inside the valve closes it creating boost in the intake manifold. The DTBPV replaces that spring with a stronger one.
The short answer to "why" if you in fact are having yo-yo symptoms...the spring in your current BPV isn't strong enough to close and hold closed the butterfly in the valve. That's the theory, anyway.
As you know already, as long as the engine is running the SC is spinning...the BPV is open because there is vacuum present. When the vacuum drops(engine under load) the spring closes the valve, and boost is created.
Hook up a vacuum/boost gauge to your engine, and you will be able to see(in comparison to throttle position) where each occurs.
EDIT: nice diagram Some Guy, very accurate.
And how does the "latest" compare to the Detroit Tuned valve? Thanks!
Sorry, I don’t have build dates. The first model was in use until at least 5/2003, the second version has different screws, same body (casting), same spring, in use during early model 2004; the latest (start date unknown, 2005 for sure) has a different body, stop limiter, and spring. The DT BPV has a much stiffer spring, all version’s butterfly plates can be adjusted by the user, the DT’s is pre-adjusted.
awesome x2. thank you.
I'm at 104k
on my car... I have only had the stocker that I modded myself, and now have a second one on the shelf for when this one fails... But then, I'm married and don't have to show off a huge collection of BPVs on date-night!
Matt
Matt
Wohnson89
Jun 10, 2020 04:53 AM
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
I was wondering about that too.
