R50/53 Just purchased 2004 MCS
Hey everyone, I just got a 2004 MCS from someone who actually used to be a user on the forums here. He took great care of it and added a bunch of aftermarket parts to it.
supercharger pulley
m7 front grills
cold air intake
magnaflow exhaust
whalen shift ****
m7 oil drip catcher
m7 air plate diverter
m7 180 thermostat
I wanted to know whats the best way to hook up an ipod to my car? I've been reading around and I see some people ordered some AUX plug from somewhere, is that pretty easy? Also, any other recommendations on any other upgrades?
supercharger pulley
m7 front grills
cold air intake
magnaflow exhaust
whalen shift ****
m7 oil drip catcher
m7 180 thermostat
Congrats, sounds like the previous owner had some nice mods!
The Aux plug is made by MINI and is probably the simplest and most economical way to get audio from your iPod into the stock stereo. It is only for audio and does not charge the iPod. I had just the Aux plug on my 2003 and it worked flawlessly. On my 2006 I have the Aux plug as well as charger hidden behind the dash and a single cable that charges and gets audio for my mounted iPhone, but this is a bit more elaborate. Do know that installation of the Aux port, requires pulling the headunit out and some dash pieces although it is very straight forward. You can find the Aux plug at any of the standard MINI boutiques:
OutMotoring
MiniCarParts
MINIMania
MorristownMINI
MorristownMINI is the cheapest currently ($29) as of 12/3/08
OutMotoring
MiniCarParts
MINIMania
MorristownMINI
The installation of the aux input port can be done without removing the head unit. It's really tight, and as long as you don't have really big hands, it can be done with a little patience! The trim piece under the steering wheel needs to be removed and you can reach behind the head unit and plug in the aux harness. I just didn't like puting the jack where MINI recommends it - in the glove box! So I installed mine in the little cover below and behind the switch panel in the center console.
lovethecorners, can you give more details on your iPod install that charges? How did you combine into a single cable? I'd love to do this too!
Congratulations! I got an '04 PW MCS about two weeks ago and loving it! I call it the rattle box but I still like it.
I was debating mounting my iPod(s)/iPhone but once I did so I was very happy, especially when the iPhone is mounted. The one-cable look is very clean and easy to accomplish. Here's my setup:
- MINI Aux adapter kit
- Radio (Boost) accessory cigarette-end power adapter loom
- Griffin Technology AutoPilot
- Panavase MINI radio mount bracket
- Generic phone/iPod mount
Yes, the Aux port will work with the H/K system. The only "problem scenario" is if you have navigation as the cable for voice commands from the satnav and the aux jack are supposed to go into the same outlet on the back of the headunit, although this can be rectified:
https://www.northamericanmotoring.co...lled-pics.html
Kimolaoha
Dec 5, 2020 09:32 PM
Spank
11
Apr 9, 2020 02:23 PM
