R50/53 Poor AM Reception in my 03 MCS.
Old Aug 9, 2008 | 01:26 PM
NCJimbo's Avatar
NCJimbo
The AM radio reception in my 03 MCS is awful; while the FM reception appears to be fine. I purchased the car used a few months ago - and I assume the sound system is stock. I haven't been able to find any worthwhile advice on-line, so I thought I would post it on NAM in hopes that someone out there might have solved this problem in the past. Anyone?
Old Aug 9, 2008 | 02:44 PM
HighLife4136's Avatar
HighLife4136
What's AM?
Old Aug 10, 2008 | 12:12 AM
retroom's Avatar
retroom
I drive without the antenna and my AM reception is fine, actually, regarding the reception, there is no difference with or without the antenna connected. BTW, my antenna is always disconnected. Yes, I have the standard radio, 2003 non-S.
retroom
Old Aug 10, 2008 | 11:45 AM
Jayhawk's Avatar
Jayhawk
I have the same problem with my '03 MCS. I admit I'm a talk radio addict. I can barely pick up local AM stations, yet my FM reception is excellent. One odd thing I've noticed is that if I turn on my Xenon headlights while the radio is on, my reception gets noticably better. If you find an answer for yours please let me know.
Jayhawk
Old Aug 11, 2008 | 03:19 PM
BrianD's Avatar
BrianD
Dump the AM & FM and get XM.
Old Aug 12, 2008 | 08:13 AM
Bigshot's Avatar
Bigshot
You might want to check the ground connection on the head unit.
Old Feb 3, 2009 | 07:35 PM
Jayhawk's Avatar
Jayhawk
Poor AM reception solved!
I finally stumbled across the cause of my poor AM reception. I took off my antenna to install my car cover and happened to look at the threaded end and noticed a thin layer of corrosion. There was also corrosion on the antenna mount. I took a small wire brush and cleaned both the antenna connection and antenna mount connection. My AM reception is now outstanding.
Jay
Old Apr 11, 2009 | 01:04 AM
Thoroughly Modern Mini's Avatar
gunna have to check that out tomorrow !
Old Apr 11, 2009 | 06:44 AM
DaveTinNY's Avatar
DaveTinNY
"One odd thing I've noticed is that if I turn on my Xenon headlights while the radio is on, my reception gets noticably better."
Must be the Low Impedance Flux Capacitor igniting a stray HF plasma around those Xenons; this in turn may distort the single side band portion of the AM channel you're tuned in to. Thus, better reception!
Same thing happens to me.
Old Apr 11, 2009 | 06:51 AM
resmini's Avatar
resmini
So, how much will it cost me to convert my standard headlights to Xenon ones?
Old Apr 11, 2009 | 08:17 AM
Charva's Avatar
Charva
I had an 03 Cooper with the same problem. The dealer installed a new radio and that ended that problem....was under warranty,
Dave
Old Apr 11, 2009 | 08:23 AM
DaveTinNY's Avatar
DaveTinNY
Seriously, the Xenons are great for seeing and avoiding DEER and other mammals that prefer to commit suicide than stay on the side of the road but I honestly can't say if the lights improve A.M. reception. Mine are on all the time when I motor so I'm not sure if the A.M. is improved. I'll have to test that theory.
Anyway, I listen to XM 98% of the time that I drive since I'm a Lifetime Subscriber. :D (Let's hope Sat Radio sticks around for a while)...
freeman727
Dec 10, 2017 04:00 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
zdw2082
Oct 5, 2015 09:59 AM
cub4bearindiana
Oct 2, 2015 09:45 AM
Septimusminious
Sep 14, 2015 08:47 PM
