R50/53 Major Mods (But Very Slow)
Old May 5, 2008 | 12:10 PM
New_MINI_Owner's Avatar
New_MINI_Owner
Ok, I own a 2005 Mini Cooper S. I have a long list of modifications that I am planning to do to my Mini that will take a long time to purchase. About 2 to 3 years. I was wondering after looking over my list that you could give suggestions or heads up if the Modifications I have picked will cause any problems or damage. I just bought my Mini and discovered the potential. So please help I am used to Modifying Jeeps not Cars.
Body Work:
  • Carbon Fiber Bonnet Scope
  • Carbon Fiber Mirror Caps
  • Carbon Fiber Wing
  • Carbon Fiber Rear Door Handle
  • Carbon Fiber Dashboard
  • Carbon Fiber Shift ****
  • Carbon Fiber Diffuser
  • Hamann Side Skirt
  • Hamann Front Bumper
  • Hamann Radiator Grille
  • Hamann PG4 Wheels 18”
Electrical:
  • Park Distance Control
  • Escort G-Timer GT1
  • Bluetooth Adapter
  • PIAA 540 Xtreme White Driving Light Kit
Engine and Other Mechanicals:
  • AFe Power Flow Intake Kit
  • Slit Second Turbo Tuner
  • High Performance Ignition Wires
  • Quaife Limited Slip Differential
  • Sachs Sport Clutch Disc Organic Racing Compound
  • Remus Exhaust
  • Adjustable Camber Kit Front & Rear
  • Rear Camber Correction Arm Kit
  • Bilstein PSS9 Coil over Suspension Kit
  • H-Sport Hollow Sway Bar Kit
  • Front Stress Bar
  • Performance Tuned Front Control Arm Bushing
  • Performance Tuned Rear Upper Engine Mount Insert
  • Performance Tuned Front Lower Engine Mount Insert
  • Rotora Brake Caliper Kit
  • Cross-Drilled Brake Rotor Set Front & Rear
  • Cool Carbon Sport Brake Pad Set Front & Rear
  • Teflon Coated Stainless Steel Braided Brake Line Kit
  • Caliper Brushing Kit
  • Sachs Sport Pressure Plate
  • Supercharger Overdrive Pulley Kit
  • Supersprint High-Flow Race Cat
  • Supersprint Muffler System (Maybe I Do Not Know Yet)
  • Supersprint Stainless Steel Header
  • Schrick Cam
  • TMS Power Package Stage 2 (See www.tunermotorsport.com for Info)
  • Conforti Shark Injector
  • Top Mount Alta Performance Intercooler
  • Progressive Water Injection System
Old May 5, 2008 | 01:28 PM
thulchatt's Avatar
thulchatt
WOW, that is one big list.
I suggest you decide first if you want to mod for looks or go.
After that get a solid game plan. If it is for go how fast will you get the mods, because that will tell you when to do things like custom tune the ECU.
Some of the mods are not necessary on a supercharger, like a turbo timer, and some are missing, like an underdrive pulley.
You may want to do some more reading here and get an idea of your go mods or call one of the vendors, I suggest Way Motor Works, to get a game plan.
Old May 5, 2008 | 01:35 PM
Malcon's Avatar
Malcon
wow thats a great list!... i agree with deciding if you want to go for performance or looks.. you can go for both but maybe you want to get the performance first then go for looks.. or the other way around.
check out the forum and see what everybody is doing. I would deff. start out with the basics. get a pulley. i like the 15%, intake and exhaust. but yeah there is so much you can do. you just need a plan with your priorities in order.
looking forward to seeing your car develop! and welcome to the forum!
-Malcon
Old May 5, 2008 | 01:38 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Taking into account the cost of all of that, and that you want to have it all bought in the next 3 years, take that wad of cash and give Jan at RMW a call. He can get you 230 hp easy for a lot less than all those other mods, and Jan's stuff is made to work together as a complete unit.
Old May 5, 2008 | 01:42 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
Step one supercharger pulley
For steps 2-50 give me a call and we'll make a plan specificly for your car and use.
WAY
317.201.8670
www.waymotorworks.com
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old May 5, 2008 | 01:43 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
WOW That is a GREAT first post! Tons of good mods in there. I can't wait to see how slow you actually do it. Sometimes the mod bug can bite pretty hard.
Let me know if I can help with anything on this build.
Old May 5, 2008 | 03:02 PM
theWING's Avatar
theWING
Looks solid, brother. Welcome to the stock club
My list looks a lot like that, not quite as much, though.
+1 for going back and forth on purchasing show and go modifications.
Old May 5, 2008 | 03:03 PM
Longboard Mini's Avatar
Longboard Mini
I played with your list a little. Hope you don't mind.
Longboard
  • AFe Power Flow Intake Kit /
  • Slit Second Turbo Tuner / What is this??
  • Sachs Sport Clutch Disc Organic Racing Compound / Clutch Master stage 3
  • Remus Exhaust / Anything other then Remus. Below you say Supersprint??
  • Bilstein PSS9 Coil over Suspension Kit / Cross
  • Front Stress Bar / OMP or TSW
  • Cross-Drilled Brake Rotor Set Front & Rear / Get solid or slotted if you plan on tracking the car
  • Caliper Brushing Kit / Not needed if you get the Rotoras
  • Supersprint High-Flow Race Cat / Big $$$
  • Supersprint Muffler System (Maybe I Do Not Know Yet) / Big $$$
  • Supersprint Stainless Steel Header / Just get the OBX
  • Schrick Cam / Don't
  • Conforti Shark Injector / Don't
Old May 5, 2008 | 03:24 PM
Jhud's Avatar
Jhud
keep plugging away at the mods list. im in the same boat as you are as far as slowly adding mods. I bought my 03 in late 06 and it was bone stock. to date:
15% Alta V1
2% Alta Crank
Alta CAI V1
Bonnet Viper stripes
35% tint all around
JCW carbon Fiber hood scoop
JCW CF mirror caps
JCW spoiler
Aux input
Invidia Catback
Beltline Blackout
Alta 3" stubby antenna
Eagle F1 GSD3 205/50/16
Pro painted intercooler cover
R53BFUN custom plate
Stewart Warner Atl/Boost guage kit
I think thats everything, Next is the JCW brake kit and then JCW 380 injectors, RMW tune, and start on the suspension.
I believe in you and good luck!
Old May 5, 2008 | 03:56 PM
Eurothrasher's Avatar
Eurothrasher
Only Familiar with Mods for JEEP ?
Nice Wish list. But you would be better off getting a slightly wrecked MINI if replacing all those components ......
BTW ~ What did you do with the JEEPS you modified ?
Race them in the Grande Prix ?
Old May 5, 2008 | 03:57 PM
New_MINI_Owner
Well Thanks for the ideas. My plan is Power and Performance First. I am however aware of the expensive costs that I am facing but my #1 goal is to make this Mini be able to roll with maybe a 911 or possibly the M3. But please do correct me if this is not possible it is my first mini, Actually thought I was to tall.
Another Idea is if you can make a totally different list and I may compare it.
Old May 5, 2008 | 03:59 PM
New_MINI_Owner
Euro I had a 4" lift on my Grand Cherokee I did a engine swap for a older jeep and Dana 44 Axels
Old May 5, 2008 | 04:11 PM
Eurothrasher
Make the Mini Breathe Better
I had a custom JEEP too ( 04 LIMITED LIBERTY ). I liked the older Liberty because it was designed by Diamler Benz, and it had the same quality too.
At the top of my "Performance list" for ANY Mini Would be to make her Breathe Better. Intake, Exhaust system, and a 15-19% Reduced Superchager pully (Alta) to raise the psi, then a Short Shift Kit. ( didn't see that on your list. ) Then Ignition and wires.
And don't forget to get some Brembo's to slow ya down.
Old May 5, 2008 | 05:28 PM
chpsk8's Avatar
chpsk8
Body Work:
  • Carbon Fiber Wing
  • Hamann Side Skirt
Electrical:
  • Bluetooth Adapter
  • Remus Exhaust
  • Front Stress Bar
  • Schrick Cam
Whats the total price tag for all that including labor? I hate to evoke my namesake, but add that to the price of the car and you're in used Elise money. Impressive, but questioning the $/HP and fun equation.
Old May 5, 2008 | 05:33 PM
New_MINI_Owner
Just Parts Alone was 17681 Roughly and about 3000 in Labor I am assuming so It evens out
Old May 5, 2008 | 06:35 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Upon further consideration, you don't need those carbon fiber bits. The MINI doesn't weigh much to begin with, and the weight savings from carbon fiber parts is slight. The cost/weight savings ratio is too high. Remove interior parts first; save money and weight.
Car Care Products
Dec 11, 2015 02:08 PM
kevinlhr310
Sep 27, 2015 02:31 PM
Sep 22, 2015 07:31 AM
Sep 18, 2015 02:44 PM
larryd96
11
Sep 8, 2015 05:01 AM
