R50/53 intake clips
Old Mar 5, 2008 | 04:59 PM
tne1870's Avatar
tne1870
intake clips
can anyone tell me how to put close the clips back on my intake? ive tried using every kind of pliers i have but no help.
Old Mar 5, 2008 | 05:03 PM
verveAbsolut's Avatar
verveAbsolut
Don't know what to say. Took a few minutes, but pliers and a small flathead screwdriver worked fine. This is what I used for the hose...hopefully we're talking about the same clips.
- Matt
Old Mar 5, 2008 | 05:18 PM
Jhud's Avatar
Jhud
its probably not on correctly, the clips are tight but not impossible. bmws and mini factory filters are notorious for being " a little big"
Old Mar 7, 2008 | 09:30 AM
sequence's Avatar
sequence
Randy Webb showed me how a small channelock pliers will do the trick--or just replace it with a screw clamp
Old Mar 7, 2008 | 12:29 PM
bthayer23's Avatar
bthayer23
+1 channel-lock pliers
Old Mar 8, 2008 | 05:01 AM
bonmot's Avatar
bonmot
My dealer-installed aftermarket intake was installed with a screw clamp. I guess they figured it was too big of a PITA to try to get the old clamp back on.
Old Mar 8, 2008 | 05:11 AM
docmini's Avatar
docmini
Agree, channel-lock pliers help, but just replacing with screw type makes it so much easier!
Old Mar 8, 2008 | 11:22 AM
Ancient Mariner's Avatar
Ancient Mariner
If you're gonna use screw clamps, use the ones designated for fuel injection whenever possible. The standard ones do not supply even pressure all around. There is significantly more pressure under the clamping mechanism, and if it is used on a plastic fitting it can cause deformation over time. The standard ones are sooo last century.
rtk90
Aug 29, 2019 09:08 AM
Grizld700
Dec 30, 2015 10:47 AM
COOPT UP
Sep 11, 2015 04:59 AM
ShadyCoop
Sep 8, 2015 04:50 PM
Sep 4, 2015 08:25 AM
