R50/53 Windows roll down on their own...
Old Feb 26, 2008 | 05:52 AM
comet5o4's Avatar
comet5o4
So my dad runs in this morning waking me up yelling that my car looks like Lake Erie. This is now the third time this has happened, I'll have locked up my car at night and then go out there in the morning and the windows will be down. The other two times it has been sunny, but today there was a thunderstorm... I know this is a function on the key, but I leave them on my desk every night, so... Anyone else had this problem?
Old Feb 26, 2008 | 07:12 AM
donniebronx's Avatar
donniebronx
No I've never heard of this but I couple times I've hit the function on the key a couple times when I've locked it and then in the morning (although mine is in the garage) my windows will be open a bit.
If it continues take the key to the dealer to possibly reconfig.
Old Feb 26, 2008 | 07:22 AM
kalvinjo's Avatar
kalvinjo
Yes, I have had this happen. I took mine in and the dealership couldnt find out what was going on or replicate the issue. Mine normally has happened in the past when its been damp, luckly only damp and not raining. The only advice the techs gave me was that they could de-program the key fob. ;
Old Feb 26, 2008 | 07:59 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Set up some large patio umbrellas or one of those foldable sun shelters to park under.
Old Feb 28, 2008 | 07:05 AM
comet5o4's Avatar
comet5o4
Yeh, I just don't see how it's doing it unless the key is somehow sending a signal without me pressing the button. It happened again last night in the snow, luckily I caught it before too much got in there.
Old Feb 28, 2008 | 07:31 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Pull the fuses for the windows. It's winter anyway, right?
Old Feb 28, 2008 | 09:21 AM
thulchatt's Avatar
thulchatt
Could be a signal from something else on the same frequency as your remote.
Just a guess but if it keeps happening and you are not pressing the remote it is possible.
Old Feb 28, 2008 | 09:44 AM
comet5o4's Avatar
comet5o4
That's what I though because it's only happening at night... I'm taking it to the dealing though to get that taken care of and a tune up while I'm at it.
Old Feb 28, 2008 | 09:46 AM
mcs22004's Avatar
mcs22004
WAD.
Old Feb 28, 2008 | 11:43 AM
chadtoolio's Avatar
chadtoolio
The BC1 is what controls this function....You need a BC1 and or check for water ingress to the BC1...I have seen about 5-6 of these over the years and have not had a repeat complaint after the repair. How close are you to Charleston, SC???
Chad
Old Feb 28, 2008 | 08:24 PM
comet5o4's Avatar
comet5o4
I'm in Asheville NC. I'm taking it to Winston-Salem where I bought it.
Old Feb 28, 2008 | 08:25 PM
comet5o4's Avatar
comet5o4
What is WAD?
Old Feb 28, 2008 | 08:44 PM
Ftgt101's Avatar
Ftgt101
My BMW M3 did this everytime you touched it the windows would go down. It was kinda funny. I found out it was a simple ground. Once the sunroof opened half way at the same time, I just figured the Gremlins were a little mad at me.
Old Feb 28, 2008 | 09:19 PM
Ancient Mariner's Avatar
Ancient Mariner
Ooooo! No, no, no! The windows won't drop and raise when the doors are opened and closed. Bad juju!
Skip
Old Feb 28, 2008 | 10:23 PM
T18DRYVER's Avatar
T18DRYVER
What is WAD?
I believe that would be "What A ****"!
Old Feb 28, 2008 | 11:47 PM
dustybottoms's Avatar
dustybottoms
Obviously you have a Mini ghost that likes the open air...
Old Feb 29, 2008 | 03:13 AM
MiniMaxx's Avatar
MiniMaxx
Search for posts from 2-3 years ago. Probably a result of the car programmed to open/close windows/sunroof with the key. Where'd everybody go? 2 years ago you'd have had folks jumping in with the threads.
Old Feb 29, 2008 | 04:40 AM
Speedwing's Avatar
Speedwing
Moisture in the BC1 main connector would be the first place to look. Un-plug big connector, dry it out, check for any signs of corrosion on the pins, spray with electric contact cleaner and plug it back together.
Now the hard part is figuring out how the moisture is getting in there!!
Old Feb 29, 2008 | 06:02 AM
mcs22004's Avatar
mcs22004
What is WAD?
Works As (mis)Designed
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
semibreve42
Oct 2, 2015 09:06 AM
rt808
Sep 25, 2015 01:59 PM
