R50/53 An amazingly pitiful question
Old Oct 11, 2007 | 06:55 AM
dwarrenku's Avatar
dwarrenku
privacy
Old Oct 11, 2007 | 07:35 AM
rubyred3's Avatar
rubyred3
Probably needs a radiator flush as well, also check your brakes (I know you say you replaced them when the time comes, so that probably means they are fine, but its an easy thing to check. If you haven't replaced the rears yet, its probably about time.
Tires are a good thing to check too, but I'm guessing you've already replaced those once. . .
Theres no need to be ashamed, you, unlike many people, RECOGNIZE that you've been ignoring your car, and understand that its bad. Thats the first step. Now just take action, and you should be all good.
Old Oct 11, 2007 | 07:36 AM
JAB 67's Avatar
JAB 67
Replace the engine and cabin air filters, NOW!!
Old Oct 11, 2007 | 07:40 AM
rubyred3's Avatar
rubyred3
ah, yes, air filter and cabin air filter are definitely due, forgot about that, you should see a good MPG increase as a consequence.
Old Oct 11, 2007 | 07:42 AM
dwarrenku's Avatar
dwarrenku
privacy
Old Oct 11, 2007 | 07:55 AM
Gromit801's Avatar
Gromit801
I would highly recommend getting on Amazon, and buying the Bentley Press Complete Official Mini Cooper repair manual.
Tell you everything you need to know, and how to do it in great detail. Best book out there for the Mini.
Old Oct 11, 2007 | 07:58 AM
rubyred3's Avatar
rubyred3
you might not wanna clean the air filter that frequently. K&N filters are great for flow, not so much for actual filtering, especially when brand new/clean. A slightly dirty K&N filters a lot better than a clean one. A clean K&N only filters with about 90% efficiency. After the first 1000 miles or so, it gets way better though (>95%), as a small amount of dirt builds up on it. I wouldn't clean it more than every 30k if I were you, each cleaning breaks it down a little bit, and makes it filter worse.
Old Oct 11, 2007 | 08:30 AM
dwarrenku's Avatar
dwarrenku
privacy
Old Oct 11, 2007 | 09:39 AM
Gil-galad's Avatar
Gil-galad
A bulk buy on Tuesday from DP (thanks to their sale) and now $75 for the Bentley repair manual (thanks to Gromit's salesmanship)...
...it's been a tough week on the wallet -- and it's only Thursday...
Old Oct 11, 2007 | 09:43 AM
Gromit801's Avatar
Gromit801
Originally Posted by dwarrenku
@ Gromit. I may have acquired the maintenance CD for the Mini through eBay, but it usually contains instructions revolving around expensive mini only tools. Does Bentley have the same type of info, or is it better/easier to follow?
BTW I like the Douglas Adam's quote. HHGTG was my favorite "Trilogy" ever.
The Bentley manual is great. There is reference to BMW tools, but they also list alternatives. It's a 3" thick book!
DNA, may he rest in peace.
Old Oct 12, 2007 | 08:07 PM
markldriskill's Avatar
markldriskill
Hoses...
In addition to the radiator flush, check all the coolant hoses at the same time. 'Twould be a shame to fill it up with brand new coolant, only to blow a hose and lose it all over the ground!
Old Oct 13, 2007 | 07:26 AM
resmini's Avatar
resmini
Also, a few years back, the POS 5-speed tranny went out and the dealer (thankfully) replaced it with the Gertrag, and I recently had the clutch go out and replaced. But beyond that, I haven't maintained anything since 40k.
Only time I ever heard of a dealer replacing a failed Midland 5-speed with a Getrag......you sure you now have a Getrag tranny?
I'd change the engine oil at least twice as often, (every 7,500 miles), as you currently are.
I'd also change the transmission fluid every 30,000 miles or so...and I'd replace the fluid with a full synthetic like Amzoil, Redline or Royal Purple.
Old Oct 15, 2007 | 04:20 PM
R50 Paul's Avatar
R50 Paul
I too am curious about the possible Midalnds to Getreg swap.....
I'll add that the belt should be changed every 50k on a Cooper. To cooling system should be flushed at 70k too....
Glad to hear a story of a higher milege early build Cooper like mine still trugging along.
Old Oct 23, 2007 | 09:42 PM
preludestuntin's Avatar
preludestuntin
-Radiator Flush
-Fuel System Cleaning
-Fuel Filter
-Wiper Blades
-Check your shocks and springs
-Check your exhaust system for any leaks
-Check your alignment
If I can think of anything else I'll update my post. Hope this helps
Old Oct 23, 2007 | 10:12 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
I am guessing that you are the original owner of your MINI. If you have the owner's manual, read what it suggests for the various servicings. It's also a good idea to lubricate various parts. I applaud you for starting this post. I bet it will help others who were too shy to ask.
patsum
26
May 29, 2021 06:29 PM
donniedarko
Oct 21, 2015 01:15 PM
rob76turbo
Sep 15, 2015 10:11 AM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Filmy
Sep 7, 2015 11:27 AM
