R50/53 clunk goes the clutch
Old Sep 20, 2007 | 11:40 PM
MiniMusician's Avatar
MiniMusician
O.k.... my 2006 R50 MC Miranda the other night, while idling in neutral in the drive-thru made a 'clunk' sound when I went to go into the 1st gear to start off. Could have sworn I had the clutch all the way in. Maybe I'm just being ****, since it's happened twice... and I dont abuse the clutch like some do.. but I do tend to think of the posts I've read here about the new MC's that are experiencing transmission problems right off the lot. Miranda has 9k on her, with 2k left for her first oil change. Or another way to look at it... the dealer is 3 hrs away (road trip and a day off work).
Is there anything 'I' can do to address this problem? Does the brake resevior have anything to do with the clutch fluid?
Thanks!
Old Sep 25, 2007 | 01:22 AM
MiniMusician
clunking clutch
Spoke to the service manager on the phone today... he said that the getrag tranny/ clutch can be noisey at times... and the clunk I hear is normal although intermittent. I'm still going to take it in on the 5th... but doubt we'll be able to duplicate the noise. You know how it is when you take your vehicle to the shop, it never makes the noise it was making a block away. I must admit though... at least its not a grinding.
Old Sep 25, 2007 | 03:56 AM
Speedwing's Avatar
Speedwing
The brakes and clutch do share the same fluid resevoir.
Old Sep 25, 2007 | 06:37 AM
polizei's Avatar
polizei
How loud is the sound, and what really does it sound like besides a "clunk?" I know mine makes a "slamming" noise sometimes when I shift into first, but that's normal as far as I know...I think it's from metal moving, but I'm not sure.
-Cody
Old Sep 25, 2007 | 07:26 AM
brutefarse's Avatar
brutefarse
the only problem I have on my 2006 MC is it won't go to 1st gear sometimes so I had to practice shifting from 2nd just to get it rolling. Reverse on the other hand is so clunky I learned to just ignore it. As long as the getrag proves reliable I can live with clunkiness=) (Cross fingers)
Old Sep 25, 2007 | 12:26 PM
polizei's Avatar
polizei
^ Ok....THAT isn't good. You should definitely get that looked at.
-Cody
Old Sep 25, 2007 | 12:56 PM
gci's Avatar
gci
My 06 MCS makes a clunking noise going from 1st to 2nd on occasions. But with it being a Getrag, I am not worried. I had a Cobalt SS with a Getrag and I put it though hell. Don't worry too much about how well they will hold up, it will do fine.
Old Sep 25, 2007 | 01:12 PM
R50 Paul's Avatar
R50 Paul
As for the fluid, check the rear section of the resevoir, just eyeball it....it should look level all the way across the resevoir. It's a chambered unit, meaning that the front ot the resevoir is for the brake fluid and the rear is ment for the clutch fluid.
That sound you decribing sounds like the clutch isn't full engaged. Even though you said it was, this could be a fluid issue. If all is well between now and your first dealer visit, make sure you tell your service advisor to at least have the techs bleed the clutch.
As for the reverse issue, here is what I do: If you are having diffuculty shifting into reverse, with the clutch in shift to second gear. Then with the clutch in shift to reverse, 95% of the time it'll go in. I have an early build cooper with the five speed Midlands, and have also made this work on a newer cooper with a Getreg. As for the six speed, I've never tried it.
Old Oct 1, 2007 | 07:20 PM
big willa's Avatar
big willa
Don't be nervous I have had my 05 cooper for 2 years now and absolutely no problems with the clutch or tranny. I feel the tranny gets smoother as more kilometres are put onto the car. Love my cooper
Old Oct 3, 2007 | 10:50 AM
goldcountrymini's Avatar
goldcountrymini
There is a problem with the clutch slave. Our 2006 Cabrio had the clutch slave replaced a few weeks ago. We pulled into a parking lot, pushed the clutch in and would not go into gear.
It is going into first gear right? You're able to find a gear?
Old Oct 16, 2007 | 10:57 AM
R50 Paul's Avatar
R50 Paul
Any resolution on this yet?
Old Oct 16, 2007 | 03:40 PM
MiniMusician
clunk went the clutch
I spoke with the Service Manager (where I purchased Miranda). As mentioned in a earlier post and as said by the Service Manager... "its a Getrag, and they can be noisey at times". He said not to worry, but said to bring it in (next time I'm in the area) and he'd check it out with me.
Since making the clunk, it hasnt happened again. Thankfully! Even when idling in neutral, and then engaging into 1st. No problem. In fact, strange as it may sound... it seems to be driving/ operating better. A lot smoother..
Old Oct 16, 2007 | 04:36 PM
R50 Paul's Avatar
R50 Paul
Hmmmm interesting. Well thats good to know!!!
Old Oct 17, 2007 | 02:54 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Yeah, Getrags are noisy when you shift and can feel rough. Ive had a few times where I couldnt get into 2nd gear. But I just shift to third and then back to second, it works. The car has personality to say the least, she goes into second when she wants to. It is a rare occurance btw.
Old Oct 17, 2007 | 04:47 AM
harryo's Avatar
harryo
My 2006 mini has 13,000 miles and I'm experiencing eratic clutch problems sometimes as I shift into reverse there will be a slight grinding sound I have the clutch fully depressed to the floor board and I sort of double clutch and she goes into gear. As I said it is erratic not every time. Has anybody else experienced this.
Old Oct 17, 2007 | 05:20 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I have, I just blip the throttle and it goes right in. This is unrelated to my clutch I think, since it did it before and after my spec clutch/release bearing mechanism replacements.
Old Oct 27, 2007 | 04:58 PM
LindaOwnsAMini's Avatar
LindaOwnsAMini
You guys are way ahead of me in "naming that part" department. But, here goes. I have a 2003 mini, bought used with about 42k mi. Her name is Lily! Anyway, have all the records and very well maintained by prior owner. Had the car now for about 5 mos. Lately I've heard a click every time I release the gas pedal and/or release the clutch. No click depressing the clutch or gas only when I release it. Took it in to have gear box oil changed and he checked out the clutch. Said nothing wrong. This is something new and I'd like to find out how to correct it. Any ideas? Thanks.
Old Oct 28, 2007 | 05:24 AM
wildcrazy442000's Avatar
wildcrazy442000
2006 MC with 14,500 miles. I just have to be smooth on the downshift into second. I have scraped the gears two or three times. It feels like I hit a detent, or stop and then need to make sure it (the gearshift) is pulled all the way back.
Old Nov 7, 2007 | 06:21 PM
MiniQooper's Avatar
MiniQooper
Little trip my daddy taught me about grinding 1st and reverse.
If it resists first gear- let the clutch out at least half way and push back.
To avoid the reverse grind - shift forward to 1st or third, then slide it into reverse...
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
