R50/53 0-60 times
Old Sep 18, 2007 | 05:00 PM
detz's Avatar
detz
0-60 times
I read this discription at the MossMini website...
"LiveWires' extremely low resistance of 250 Ohms per wire, nearly 13 times less than stock wires, provides a path for optimum spark. Feature a durable and long-lasting silicone jacket with swivel boots for easy installation. Heat shrunk boot ends keep dirt and moisture away from terminal ends. Installation of LiveWires and Screamin' Demon Coil have yielded consistent 0-60MPH times up to 1 second quicker."
Can anyone confirm this statement? How is it possible?
detz
Old Sep 18, 2007 | 05:09 PM
chpsk8's Avatar
chpsk8
The only thing I can think of is if the wires were so shot that the motor was running very poorly. Then just about anything would be an improvement.
Moss has a way with words... let's just put it that way. I get catalogs for Miata, Mini and Triumph and they all "embellish a touch".
Old Sep 18, 2007 | 05:14 PM
minimarks's Avatar
minimarks
In a word...NO. Someone please correct me if I an wrong and I'll be the first to order a set...
Old Sep 18, 2007 | 05:46 PM
NMgokart's Avatar
NMgokart
Unless your plugs/ wires/ coil are completely worn out, replacing same is just a bling thing. Your money is better spent elsewhere.
Old Sep 18, 2007 | 07:16 PM
Some Guy's Avatar
Some Guy
+1
Old Sep 18, 2007 | 07:20 PM
Newdl's Avatar
Newdl
If you are having a problem...you should replace them....if not....i would wait until you do....
Old Sep 18, 2007 | 07:31 PM
Dan00Hawk's Avatar
Dan00Hawk
Yes you would likely see a 1 second improvement in 0-60 by installing the Live Wires and Demon Coil kit IF one of your original plug wires had been disconnected/broken to begin with...
Old Sep 18, 2007 | 07:58 PM
davisflyer's Avatar
davisflyer
"....have yielded consistent 0-60MPH times up to 1 second quicker."Key words "up to". The question is, measured against what???
Old Sep 18, 2007 | 08:12 PM
gvoelker's Avatar
gvoelker
I'm ordering mine now!!!
Old Sep 19, 2007 | 09:32 AM
eager2own's Avatar
eager2own
I'm hoping the 1 second quicker results from each wire -- so I've ordered a set of 4.
0-60 in 2.7
Old Sep 19, 2007 | 09:46 AM
Silverbullit's Avatar
Silverbullit
All you Supercar owners out there be aware that eager2own will be out there looking to whup your butts with his 2.7 MINI!!!
Old Sep 19, 2007 | 06:52 PM
Paul!'s Avatar
Paul!
If you want real performance, you need to get the wires from KaleCo Auto!
-Paul!
Old Sep 20, 2007 | 03:15 PM
chows4us's Avatar
chows4us
Maybe somebody can buy two sets and drop 2 seconds?
eatsleepautox
Oct 30, 2015 06:46 AM
bjcarter2
Aug 31, 2015 04:03 PM
Aug 12, 2015 01:24 PM
wind715
Aug 11, 2015 07:56 AM
