R50/53 Retrofit cold weather accessories
Has anyone retrofitted cold weather add-ons such as the heated mirrors, heated seats, window washer, etc?
We're mov'n from the hot southwest to the cold midwest. Dealer here in hot country has no clue.
_________________
Fix it 'til it breaks ->Mini-Pearl: Pepper White / Red Interior / Red Stripes / CVT
_________________
Anyone? ...Bueller?
I'm surprised no one has answered this yet. I want to retrofit the full package to my car as well. Do all R53s have the chassis wiring in place to connect the actual switches and heated bits? Or do I need to run all the wires as well?
Doubt any of the parts are still stocked....some, like the seat heater elements were always very $$$.
The answer on wirings dependd on production date....
Some mini's at one poit got seats with heating elements that were not hooked up...forgot the year, but it was pretty random.
Remember, the last gen1 car was a 2008 model year cabrio....so its,been a bit...
Hi, First post, since I still dont have my Mini, The car that Im lloking at does not have the heated seats but I would love to have them, I was looking at this retrofit kit from ECS Tuning. http://www.ecstuning.com/Mini-2005-C...eats/ES159515/
I hope it helps
Good luck
I hope it helps
Good luck
I hope it helps
Good luck
I hope it helps
Good luck
Hi, Thanks, you are right this is the note that they have on the website.
Production: 12/2001-
Switch not for power fold option mirrors.
Note : You will have to check under your MINI seats ( passenger and driver towards the front under the bottom cushion) to see if the extra seat plug/ emply plug socket is there for this upgrade to work.
Some folks did luck out...but most cars that were owned by folks "in the know" that were lucky did this upgrade long ago!!
If you are lucky....Congrats!!
Good luck, and Great find to find the kit!!
I hope it helps
Good luck
I hope it helps
Good luck
So far if all goes well Im getting a 2005 Black on Black, H/K stereo, No fogs, will add later I hope, it is Stock as far as I can tell, They are changing the coolant tank I read that is a usual problem, also it does not have ASC, but ASC instead, not sure if is good or bad, No HID but I don't mind. I'll look under the seats maybe I'll be lucky to have the element.
Cheers and thanks
no pictures
Well all the plugs under my seat are taken so that means that I can not retrofit the heaters, I think that I saw somewhere on the web some aftermarket seat covers that would have them built in, but I could be wrong. Good luck
techgearpro
Jul 23, 2019 07:09 PM
molala
Oct 2, 2015 01:53 PM
