Navigation & Audio Anyone get the new portable NAV?
Old Apr 15, 2007 | 07:49 AM
  #26
Mini Fireman's Avatar
Mini Fireman
Originally Posted by Nor_Cal_Mini
yup, i see the files on there when I run it in mass storage mode. There are like 6 minis. Any suggestion on a site where I can post these 12 megs?
Zip them up and create a torrent for the file. Share the torrent and then as others DL the file they can share it out. There are also many free hosting sites like:
http://www.mediamax.com/
http://www.xdrive.com/
  #27
BlimeyCabrio's Avatar
BlimeyCabrio
Originally Posted by 03ibmini
I did find the solution to have the audio routed to the drivers side speaker. once again Mikey from Newministuff.com to the rescue http://www.newministuff.com/new/shop...tshow&id=188// I am going to be ordering the MINI kit for my 03 and will be purchasing this adapter from mikey to get the full integration.
Note that, unless Mikey has changed it, this kit does NOT work very well with the Nuvi. I have it. The problem is that the kit was designed for units with an external SPEAKER output, not a HEADPHONE output like the Nuvi. The level coming out of the Nuvi isn't high enough to even trigger the circuit that "cuts over" the audio on the right channel, unless you set the Nuvi volume to max - and then it cuts over, but it's not even close to loud enough to be heard. I worked around this by adding a boostaroo between the Nuvi and the kit, but even that isn't really loud enough. Mikey needs to build one with a different switching circuit or different sensitivity for units with headphone level outputs...
I use it with the aux output extensively with mp3s and a 4GB SD card - that works very well (though the voice level can still be a little quiet compared to the mp3 playback level). But I wish Mikey's kit worked well, because it would be great to have that capability for all sources including radio.
Old Apr 15, 2007 | 08:19 AM
  #28
blalor's Avatar
blalor
Thanks for that bit of info, Blimey. I've been planning on getting one of those kits and building a mixer so that I can run (at a minimum) GPS and FRS audio through it. Guess I'll have to boost the levels as part of that circuit...
Old Apr 15, 2007 | 09:02 AM
  #29
hunter99's Avatar
hunter99
OK, here is the link for the SRF files. MINI SRF vehicle files for Garmin NUVI. Remember to thank NOR_CAL_MINI for being nice enough to provide them.
Old Apr 15, 2007 | 09:04 AM
  #30
hunter99's Avatar
hunter99
I think these are cool but I do have to admit I wish they had a PW one. Can't have everything!!!!! Thanks again NOR_CAL_MINI
Old Apr 15, 2007 | 09:26 AM
  #31
Nor_Cal_Mini's Avatar
Nor_Cal_Mini
sent you the files Hunter...
wow you are quick...up and posted before i can even reply!
Old Apr 15, 2007 | 09:37 AM
  #32
BFG9000's Avatar
BFG9000
The srf files are fabulous, thanks Nor_Cal_Mini and hunter99! How about the MINI splash screens in the JPEG folder?
Old Apr 15, 2007 | 09:41 AM
  #33
Scavenger's Avatar
Scavenger
Thanks Hunter99
Darn, no space blue
Are there any other files that are different from standard?
Old Apr 15, 2007 | 10:36 AM
  #34
hunter99's Avatar
hunter99
Glad I could post them. The splash screen is also on the international MINI site. It's in the downloads section under mobile devices or something like that. They car colors are a little limited but the fact that i can have a MINI on teh screen is good enough for me.
Old Apr 15, 2007 | 11:16 AM
  #35
Crashton's Avatar
Crashton
Thanks for this.
OK who can walk a non tech old fart through the process on getting these onto his Nuvi 350? Just got the Nuvi & I'm a Nuvi newbe.
Old Apr 15, 2007 | 11:26 AM
  #36
Scavenger's Avatar
Scavenger
It's fairly simple, Plug in the Nuvi using the USB cable and Windows will map a drive letter (as a removeable drive) to the contents of your Nuvi. There's a Garmin\Vehicles folder for the srf files.
Old Apr 15, 2007 | 11:32 AM
  #37
Tribblez's Avatar
Tribblez
Thanks Nor_Cal_Mini -- you're the best!
Old Apr 15, 2007 | 01:55 PM
  #38
Funk_Flex's Avatar
Funk_Flex
I saw one installed on a R56 at a launch party. Sweet install. But since I live in NYC, I wouldn't go that route. Since the mount is in plain view, that's pretty much a open invite for thieves to break into your car to see if you stashed the nav in the glovebox.
I had a friend break who's car was broken into b/c he left a ipod powercord plugged in.
Old Apr 15, 2007 | 03:05 PM
  #39
Scavenger's Avatar
Scavenger
So, is there a different MINI specific mount released or not? If so, I'd like to see some pictures, especially if it works in the R53.
Old Apr 15, 2007 | 03:10 PM
  #40
hunter99's Avatar
hunter99
Scavenger there are pics ont eh first page of this thread. NOR_CAL_MINI I have a quick question. When you have the unit plugged into the computer can you see the MINI specific POI's? Since I am planning on some traveling, it would be nice to have a quick way to find a dealer if I ever needed one.
Old Apr 15, 2007 | 03:25 PM
  #41
ScottRiqui's Avatar
ScottRiqui
Well, good new / bad news. From the pictures in post #16, it looks like the MINI mount for the Nuvi provides the standard Garmin "ball" attachment, so it would be possible to attach a 660 bracket to the MINI mount, but it looks like the ball is too close to the tachometer to allow the 660 to physically fit.
Plus, it doesn't sound like the integration of the GPS with the car's other systems goes beyond a hardwired power lead.
Guess I'll be going with a RAM mount instead.
Old Apr 15, 2007 | 05:49 PM
  #42
minimaximini's Avatar
minimaximini
Was thinking at exactly the same thing...
...yes - the ball mount is fine - and I bet that is a simple cable too. But... Unless the mount pivots somehow - to distance the ball from the tachometer - the ball mount will not fit the 6x0 device.
Thank you for the SRF files. Now - for completeness (yes - WE are greedy) - if you see any fancy-schmancy bitmap files in the Garmin/Pictures directory...
Thank you a lot for your pictures and the SRFs - MMM
Old Apr 15, 2007 | 09:23 PM
  #43
Scavenger's Avatar
Scavenger
I just looked at the pictures of the mount on the first page. In that post was mention of inadequate volume level. Well, if you do a firmware upgrade, the volume has been boosted!
Edit: More questions... Is the bracket reversible so that the Nuvi can be mounted on the right-hand side of the column? Also, will it work with the Chrono Pack - meaning - I have both gauges on the column?
Old Apr 16, 2007 | 05:07 PM
  #44
MMM's Avatar
MMM
Thanks, NOR_CAL_MINI. It was good of you to share those files!
Old Apr 16, 2007 | 05:59 PM
  #45
blalor's Avatar
blalor
Splash screen
Here's the splash screen I use; it's a 415x368 image I got off the int'l MINI site. It looks like it was meant for the nüvi!
I'm pretty impressed with the MINI vehicle icons; I've got the BRG one with the Union Jack roof set up on my nüvi. I'm kind of disappointed they don't have a CR/B one, though!
Old Apr 17, 2007 | 12:14 AM
  #46
Mini Fireman
Nor_Cal_Mini,
Thanks again for posting the files. Is there more than one MINI splash screen included? If so, can you post those files as well. Much appreciated.
Old Apr 17, 2007 | 05:21 AM
  #47
minimaximini
Yes, the files would be...
First - thank you again for the SRFs. They work great - and there is even a silver MINI that is similar with mine!
There might be 2 files of interest:
- the splash screen (yes - I made one too - but the original might be bigger/better/faster/more...)
- the Custom Points of Interest (also in the Garmin folder there is a custom POI subdirectory. Should be a small file - few Ks or so I suspect - with the MINI/BMW dealerships).
Again - thanks a lot for the SRFs and for the images...
MMM
Old Apr 17, 2007 | 06:11 AM
  #48
hunter99's Avatar
hunter99
NOR_CAL_MINI if you decide to get these I can post them with the other files tonight. Otherwisw, I still thank you very much for supplying the MINI srf ones.
Old Apr 17, 2007 | 06:28 PM
  #49
rocketdays's Avatar
rocketdays
Thanks for the info and photos, Nor_Cal_Mini. I hate the square peg / round hole look of the factory nav, so I'm thrilled to see there's a dealer option with a cleaner look (in my opinion, at least). I called my dealer this afternoon about having the portable nav installed.
Old Apr 17, 2007 | 08:30 PM
  #50
kulmini's Avatar
kulmini
Person of Interest
Thanks Nor_Cal_Mini for the .srf files they work just fine and also thanks to hunter99 for facilitating the file transfer.
Now is there any one out there who can edit one of the .srf file and change one of the minis to a PW/B....................please and thanks.....
