Navigation & Audio My Stealth iPod Install
Old Jan 14, 2006 | 12:59 PM
Pir8 97's Avatar
Pir8 97
I been thinking of changing the location of my iPod. I had it under the ebrake, but it cluttered up the area especially w/ my hands-free unit next to it and I don't like the idea of it being visible from the outside.
I don't know if anyone has done this yet, but here is my solution.
Now you see it...
Now you don't...
I can easily pull it out if I want to take it somewhere. I use my HU to control it so there's no need to have easy access to the controls while driving.
Old Jan 14, 2006 | 01:27 PM
Eric_Rowland's Avatar
Eric_Rowland
Looks great. What was your address?
So are you using the OEM ipod adapter or the Dennison?
Old Jan 14, 2006 | 04:28 PM
The MINITOR's Avatar
The MINITOR
I'm confused, where'd it go?
Old Jan 14, 2006 | 04:43 PM
astrochex's Avatar
astrochex
Is this one of those before-and-after types of photography used in wrinkle/balding commercials?
The angle on the second picture is a little higher than on the first. There is a piece of dashboard trim in the second that is not in the first. Is it hiding in there?
Very clean, nice job!
Old Jan 14, 2006 | 04:49 PM
rkw's Avatar
rkw
It looks like it is attached to the inside of the knee bolster, which is hinged open in the first photograph. This technique won't work for those of us with the Euro parcel shelf.
Old Jan 14, 2006 | 05:26 PM
Pir8 97's Avatar
Pir8 97
You are correct The first pic is open, the second is closed.
Old Jan 14, 2006 | 05:35 PM
MandaBoo's Avatar
MandaBoo
Yeah, but I've found that if you run your wire to the parcel shelf and just set your iPod on it, it stays in place and you can't see it from outside the car.
Old Jan 14, 2006 | 06:21 PM
mdsbrain's Avatar
mdsbrain
Good idea
Old Jan 19, 2006 | 09:06 AM
Zarrik's Avatar
Zarrik
That's how I've got mine set up. I ran the iPod adapter wire from the HU, out the left side, and in the gap between the steering column and the parcel shelf. Funny enough, I already had a black case for my ipod to prevent scratching, but it doubles as a way to blend the ipod in even more. It is hidden well enough that I often forget to bring it inside on cold days, while the Mini sleeps in the driveway
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
