Navigation & Audio NAV Software V26 Released
Originally Posted by mingus
My Local dealer says they will update my V4 Nav to the current software for $123. mine is 21.2. I have the file, just thinking it may be better to have the dealer do it in case somethng would happen? Wonder what version they will use?
the new 2005 DVD is $199. Someone said it's dual-layer.
Just in case I decide to do the flash. what mode should the nav be in when I put the CD in?
$123? FOR A 5 MINUTE JOB...
Do it yourself and if you screw it up, (don't know how that would be possible) bring it to them.
All you do is put a disk in and wait for a few minutes till the nave screen says done.
I'm in Fayetteville NC, If your close I can help you. Its VERY simple, in no way worth $123. If anything they should do for nothing.
Paul
Paul
Paul
Is your car still under warranty? I had BMW update the nav software on my 3 series several times and was never charged for it - it was during the warranty however. When I brought the 05 MCS in and asked about the nav software a ways back they seemed like they would update it with no problem if they only knew anything about the latest version :P
Past warranty tho and they want to charge you for everything - I would DIY or, if you are really worried about it, call around to several dealers and see what they would charge. It is a 5 minute job but the dealers seem to have a half hour minimum charge, so it all depends on their rates and how fair they are. Doing it yourself should be fine, the only variable I can think of would be if you had an older car with a much earlier version of software that you were upgrading, but I think people here have been fine...
I really want this
Thanks for all this info ...
I really want to do this upgrade.
Me noo compooter xpert.:impatient
I am tentative as the last time I attempted an upgrade (brit voice) I had a LOCK UP and the dealer had to install a new unit.
I just acted dumb ... wasn't hard
OK so I really do I mean REALLY want the latest up grade AND Brit voice.
I burnt the new version CD from the link here.
SO SHOULD I DO IT ?
Is the correct way to do a BRIT voice THEN the up grade or vise versa
thanks for any help
SO SHOULD I DO IT ?
thanks for any help
SO SHOULD I DO IT ?
thanks for any help
SO SHOULD I DO IT ?
thanks for any help
bpago, what version are you currently on? CD or DVD?
The upgrade/brit voice are coincident - you upgrade the software with the british voice 'hack'.
When did you have the 'lock up'?
version
I am version 4-1/40
The lock up was about 6 months ago.
I don't recall who, but someone sent me the disc
Very nice but it didn't work...
after i put in the 26 up-date disc and it does its thing...
I replace the disc that i took out ???
This is the link I used and burnt
so is this the up date & brit ???
Yes! it worked for me. Does look a lot better. not sure if the voice sounds different yet. burned at 12x on my Plextor with Alcohol 120% and Taiyo Yuden media. Thanks everyone.
Now for the new 2005 DVD. Dealer said $199, will check with Navteq tomorrow.
OK
I burnt the up grade and went for the load today
I got "INCORRECT CD/DVD.......................
I will buy a copy from someone if you think thats my problem.
Originally Posted by samiam01
are you burning an image or a copy?
See I AM over my head
I downloaded it and burnt it ...
Still think I need to talk someone out af a disc
Image ??? Copy ???
Then insert into Navi drive.
bpago,
If you still have problems after mdsbrain's instructions, catch me on one of the IM clients (see my message header, I am on all of the major ones) and I'll be happy to chat with you about it.
I had a problem
When I first loaded the new firmware the nav had my vehicle traveling about 50 feet south of where I was (of the road). Once I turned off the car and restarted it seemed OK. Well that was until I was using it the next day. The position of the car seemed correct but the route would not update and the direction arrow on the right side was flashing and the only thing it would do is point to the south-east of the car and keep updating the distance for the turn (50, 100, 200...)
I reflashed the software and it seemed to correct itself... was I the only one to have this issue?
