Navigation & Audio What cable do I need to use Pandora with mini connected?
Old Feb 2, 2018 | 07:20 AM
jennster's Avatar
jennster
When I open it on my phone I can see the calendar on my screen but no Pandora . I'm reading you need a special cable (please correct me if I'm wrong). Which would I need for my Android.
Old Feb 2, 2018 | 09:24 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
I have an iphone and it works when I connect it to the charging cable
Old Feb 2, 2018 | 10:23 AM
jennster's Avatar
jennster
That's the thing I've tried that and it didn't work : /
Old Feb 2, 2018 | 10:27 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
No expert, but we would need to know what year/car/level of audio system. My F56 basic HK radio is far different than our F55 fully loaded stereo in how to access phone apps.
Old Feb 2, 2018 | 10:02 PM
vetsvette's Avatar
vetsvette
Moderator
Mine works fine with a standard lightning cable.
Old Feb 7, 2018 | 04:43 PM
siriuszero's Avatar
siriuszero
No special cable needed if you have a newer MINI - just the Apple USB cable should work fine. If you're using a non-OEM cable, that may be the problem. MINIs are very finicky with 3rd party cables.
Old Feb 7, 2018 | 09:01 PM
MannyJimenez's Avatar
MannyJimenez
We need more info
Year/Model/Radio Package and which iPhone
If not, then you’re going to get all the newer cars stating “just the iPhone lightning charge cable is needed”
Either you have a pre 2015 model without the Mini Connect or you are asking about Connecting via Bluetooth or the USB/3.5mm Jack to lightning cable or 30 pin
Old Feb 8, 2018 | 05:40 AM
StephenM's Avatar
StephenM
Just to be clear folks, OP stated Android, not iPhone.
Old Feb 8, 2018 | 12:01 PM
siriuszero's Avatar
siriuszero
I did not see that before...
In that case, I don't believe MINI Connected for Android supports Pandora or anything else besides calendar. BT Audio or AUX are your only options.
bbart12
R60/R61 Stock Problems/Issues
Nov 6, 2011 05:43 AM
Ginvent
11
Apr 5, 2011 05:37 PM
arisoup
Mar 13, 2011 09:24 PM
VGNCLUB
Jan 27, 2011 08:41 AM
03mini-S
11
Jan 6, 2011 09:23 PM
