Navigation & Audio Replaced radio now aux input gone
Old Jun 28, 2015 | 04:05 PM
mrbug's Avatar
mrbug
I had the factory unit replaced with another because the screen died. The new unit does not have an aux input anymore just a sub input. Is there a setting I can change to get it back? It is a 2009 base convertible.
Old Mar 11, 2019 | 09:11 PM
Jorge Mujica's Avatar
Jorge Mujica
Hi, were you able to solve this?
Old Mar 22, 2019 | 05:39 AM
mdc9966's Avatar
mdc9966
So I swapped radios (know working unit) and that didn't fix the acquiring signal issue, then I added an aftermarket Sat antenna (verified it worked on my other car) to use on the Sat receiver under the seat, still no sat signal.
Any ideas?
I can take it to the dealer for $125 an hour to trouble shoot.
Maybe swap out the Sat receiver? It recognizes the Sat receiver is there, it shows as an option on the radio. When I unplug the Sat receiver the option of Sat goes away on the radio.
Check for an update software (anyway to check this other than going to the dealer?)
Open to thoughts, just trying to get the Sat radio to work.
Old Mar 22, 2019 | 05:44 AM
Jorge Mujica
Any ideas?
Hi, i did the same, bought another radio from Ebay. Plug it in and same Issue !!!! Aux was not recognized. Fianlly took it to a Mini Shop and they had to recode the computer to fix it, aprox $280. Apparently the one that was on the car was already a swap. Then i just returned the 2nd radio back to the dealer. Seems like theres a whole bunch of R56 stereos with this problem around.
Seems far from NC, but give them a call, maybe they can refer you to someone close to your house. https://www.markertmotorworks.com/
Old Mar 22, 2019 | 06:45 AM
mdc9966's Avatar
mdc9966
I called them and they didn't offer anyone in the Charlotte area.
My problem is not the Aux connection. That and the USB work fine. Mine is stuck in Acquiring Signal when you switch to Sat radio.
Thanks,
Old Apr 14, 2019 | 06:18 AM
miniminim's Avatar
miniminim
Similar problem here. I swapped the radio and lost AUX. Now it has USB but no USB port. I was using AUX for Bluetooth and handsfree phone. Now what?
Old Apr 15, 2019 | 04:34 AM
Jorge Mujica
Hey, so i have an R56 2010. Apparently for that year USB and Bluetooth was or not available. In my case i only have the AUX In port. So i bought a refurbioshed radio on Ebay, worked fine but exaclty the same problem AUX option was not available on the display. Finally i end up going to some mini expert garage near ATL and they had to re code the stereo. I kept the one that came with the car and return the new one i bought. Hope this helps.
Shop-Garage: https://www.markertmotorworks.com/
Ebay seller: https://www.ebay.com/usr/bluestarcar...p2047675.l2559
Old Apr 15, 2019 | 04:45 AM
miniminim's Avatar
miniminim
Is there a way to add a USB port in place of the AUX ?
Or to reprogram the radio?
I can't face all those screws again.
Old Apr 15, 2019 | 05:23 AM
Jorge Mujica
jeje, yeah i know, hard to get that thing off and worst to get it back as it was. As far as they told me at the shop, no, it wasnt possible for that stereo. But i think that if you go to the following model, the same stereo but black that did come with USB and ive read somewhere that with some parts change it can be fitted. On the other hand theres a adapter, GROM MST that plugged behind the radio can give you USB and BT even keeping the wheel controls. To be honest i have not found many reviews about it. https://gromaudio.com/
Old Apr 15, 2019 | 10:14 AM
miniminim's Avatar
miniminim
$299 Phew
Old Apr 24, 2019 | 10:45 AM
miniminim's Avatar
miniminim
I swapped the radio and lost AUX. Radio has USB but no USB port on the car. I was using AUX for Bluetooth and handsfree phone. Found this on ebay will it solve the problem?
StillK
R55 :: Clubman Talk (2008+)
Dec 7, 2022 08:19 AM
W0TM8
Dec 19, 2019 07:50 AM
surfblue
Oct 24, 2018 01:20 AM
veevsato
Aug 5, 2015 04:42 AM
