Navigation & Audio Retrofit Sirius into my 2008
Old Jun 27, 2013 | 05:56 AM
drdave's Avatar
drdave
I am currently using an XM Direct unit in my convertible and would like to switch to the factory Sirius. What is needed for the install and is it still available?
Old Jun 27, 2013 | 08:30 AM
For the factory kit for the R52 MINI convertible Models.
SIRIUS IBUS Receiver - MINI version Part number 65120439447
fits 9/2002- R50 R53 and 9/2004- R52
http://www.ecstuning.com/Search/SiteSearch/65120439447/
SIRIUS Installation Kit - R52 MINI Convertible Part number 65110415298
http://www.ecstuning.com/Search/SiteSearch/65110415298/
It running the factory CD changer they call for the Y cable .
SIRIUS Y Cable Extension
http://www.ecstuning.com/Search/SiteSearch/84110141978/ES200589/
For MINIs with Harman Kardon sound system, they will also need the antenna Cable extension.
Antenna Cable Part number 65120397738
http://www.ecstuning.com/Search/SiteSearch/65120397738/
I remember early R52 convertibles did not have the satellite prep antenna and had to run the external Sat antenna, check your antenna for the extra plug or little sat antenna chip mounted in the housing under the cover facing forward. Some people on the forums that did not have Sat prep pre wired have modded the LP antenna (or one like it ) to fit into the housing. So if you don't have the prep , you will not have the extra external antenna on the outside.
SIRIUS LP Antenna Part number 65200034887
http://www.ecstuning.com/Search/SiteSearch/65200034887/
Thanks and hope that helps.
Old Jun 27, 2013 | 01:18 PM
joylove's Avatar
joylove
Just to expand on the above, there was never an SDARS antenna base for the cabrio. GPS/GSM/FM yes, at $312. http://realoem.com/bmw/showparts.do?...59&hg=65&fg=30 The hardtop got an SDARS base but not the cabrio. Others have modded it.
The retrofit kit is only needed if you don't have a black box under the passenger seat with the HK amp inside. You only can use the bracket for that situation. Plus you can't get the cables in, the rubber bung is too tight to accept the terminations.
The Y cable is required only if you are stuck in 1993 listening to a CD changer. The right angle adaptor is too cheap not to order as it aids installation.
Old Jun 27, 2013 | 05:14 PM
drdave's Avatar
drdave
Thanks guys. So, the Sirius tuner plus assorted installation kit and cables are $600+ to get me started. I have the HK stereo but not the CD changer. I didn't browse the mods for the antenna base yet. Will the small Sirius antenna be sufficient and where does the Sirius tuner mount? By the way, my car is a late build.
Old Jun 27, 2013 | 05:17 PM
joylove's Avatar
joylove
Check out the link in my Sig.
I used this antenna. Works best with a clear sky view and a metal base (the roof) to resonate against. i have OEM Sirius in my X3. When I park in my garage, the Mini holds the signal for longer, so there is no problem with signal strength even though it's an XM antenna.
I had it on the passenger side for a while, however overhanging trees gave me dropout, so I moved to to the driver side where there are usually less trees.
Amazon.com: Terk XMICRO2 Single INPUT High Performance Roof Mount XM Antenna: Electronics Amazon.com: Terk XMICRO2 Single INPUT High Performance Roof Mount XM Antenna: Electronics
Old Jun 28, 2013 | 06:52 AM
drdave's Avatar
drdave
I currently have XM and use that same antenna. I just want to go to the factory install.
Old Jun 28, 2013 | 08:00 AM
joylove's Avatar
joylove
There is no factory antenna. Check out the link in post 3 for a modded one.
Old Jun 28, 2013 | 04:35 PM
drdave's Avatar
drdave
Then, what was used for the factory installed Sirius antenna?
Old Jun 28, 2013 | 06:43 PM
joylove's Avatar
joylove
For the verts? Never got it. The Sirius antenna would have SDARS support, and you can see that in the realoem link, SDARS is not supported.
scottselk
Jul 20, 2019 06:43 AM
GregoryK
Dec 14, 2015 01:34 PM
ahorvath
Oct 3, 2015 01:13 AM
simo711
Oct 1, 2015 05:36 AM
