Navigation & Audio How to get my music to play from iPhone via Bluetooth?
Old Apr 17, 2013 | 06:15 PM
Systemlord's Avatar
Systemlord
I have been able to receive phone calls via my radio when driving which is tremendously convenient and safe, why can't I get my music to play through as well?
Thanks Mini community.
Regards,
Systemlord.
Old Apr 17, 2013 | 06:27 PM
Eric_Rowland's Avatar
Eric_Rowland
First question is what BT system do you have installed?
Old Apr 17, 2013 | 08:15 PM
Systemlord's Avatar
Systemlord
How would I find out (2007 MCS), I'm not sure what you mean by what Bluetooth system do I have?
Old Apr 21, 2013 | 04:14 PM
mojo_9's Avatar
mojo_9
Hi,
I have a 2008 Cooper S and also have the factory BT system that let's you make and receive calls from your phone via BT. The reason why you can't play music via BT is because it only uses an older version of BT and does not support it. It's possible that an adaptor could be plugged in to the iphone connector to enable it.
If you find an adaptor that works let me know.
cheers,
Jim
Old Apr 21, 2013 | 11:08 PM
Eric_Rowland
Installed aftermarket BT systems are quite rare, and the OEM system even more rare. The OEM uses a separate keypad, and I believe the Parrot system does, too.
The system you have will determine the options you have (if any) to get music.
Old May 10, 2013 | 05:35 AM
mcmmotorsports's Avatar
mcmmotorsports
Has anyone had success playing music through the OEM Bluetooth system with an Android device?
Old May 10, 2013 | 05:57 AM
Soulmaker1's Avatar
Soulmaker1
the tune2air BT module works great in my MCS 2013. We connect Android an Apple devices with no problems.
Old Jun 8, 2013 | 09:41 AM
BlwnAway's Avatar
BlwnAway
Not new, but I just found it.
HTC Bluetooth Audio Adaptor, works w/ any bluetooth device, charges w/ micro-usb, 5-6 hrs of use or keep it plugged in. All the reviews seem good. $40-$60.
Old Jun 8, 2013 | 10:08 AM
zigziggityzoo's Avatar
zigziggityzoo
Had to do the same thing for my BMW. I got the Miccus BlueBridge: http://amzn.com/B0038MA11U
Works well for what I needed.
Old Jun 8, 2013 | 10:18 AM
ASKtheteach's Avatar
ASKtheteach
This has been discussed ad nauseum around here. The bluetooth in the basic and upgraded H/K audio systems will only handle phone calls (although it will also do turn-by-turn directions in Google Maps too). Only the MINI Connected option (with or without nav) will allow you to stream music wirelessly.
Old Jun 8, 2013 | 10:40 AM
BlwnAway's Avatar
BlwnAway
Thats why I thought this was such a great little device, size of a flash drive & will work with any haed unit with an aux input.
Old Jun 8, 2013 | 10:49 AM
kavatski's Avatar
kavatski
Yes, the fact that you can't stream music is well-established but I wasn't aware of these adapters. Will definitely be looking at picking one of those up. The car we traded on the Mini had a touchscreen system with streaming and jukebox storage so I'm missing that flexibility.
Old Jun 8, 2013 | 11:13 AM
BlwnAway's Avatar
BlwnAway
I basiclly got it for work, I drive for a living so it'll have a duel purpose for me, car & truck with one device, anything to save a buck or two for other car goodies.
IQRaceworks
53
Jun 28, 2024 07:29 AM
minimofo
Dec 26, 2015 12:03 PM
rikaro
Nov 24, 2015 02:05 PM
bradstyle
Oct 1, 2015 11:15 AM
