Navigation & Audio Getting to the Headunit (player) in an R50
Much appreciate all info about installing an aux-port... Most of this info seems to center on the wiring but have not found much on simply getting to the back of the headunit (player) itself. My Bently manual is useless and I'm worried about breaking some of the plastic mount points when disassembling the fascia uprights, etc., among other things. For the ten years I've had my Mini this concern has kept me from hooking up an Aux port, but the time has finally come to install one. I've got an Aux-port kit (from Out Motoring) now and was hoping someone might have some instructions on how to disassemble the upright console to get to the headunit? Thanks.
do you have the aux-input install instructions?
http://www.minimania.com/pdfile/NMI7647_INSTR.pdf
many people have installed this w/out removing the radio - having seen the picture from the install instructions you have an idea of what you're looking for and you CAN get your hand to the back side of the radio from the pass' side. If you can find the harness you should be able to find the empty socket for the aux' cable.
However if you must remove the radio ... you will pull the panel under the steering wheel down - it will pivot down from the back side - and open the glove box. Then remove the torx on the downtubes either side of the radio. Then they may slide down enuf to get them off, if not you'll need to loosen the center console to give yourself some more room. You don't need to remove the console, just get it loose.
Once you remove the downtube covers, you'll see the mounting screws for the radio....
but like I said you can get the aux in w/out doing this..... Know any other owners? Any of them have an aux in?
bring it by and I can put it in in about 3 minutes (not including mounting the other end)
Guys… Thanks for your references. I’ll definitely feel a lot better about diving into my console/dash with this info. FYI, I’m thinking of mounting the mini jack (port) half way up the inside of the right downtube for a more convenient access for both driver and passenger rather than the panel beneath the toggles (or the glove box). Any suggestions on iPod connect cables? I want to access the audio through the apple connector rather than the earbud jack and at the same time power/recharge it when in use…
you want the iPOD interface then ... not the aux input? (I'm not an iPOD person)
http://www.outmotoring.com/mini-coop...interface.html
lot's more $$
http://www.minimania.com/pdfile/NMI4405_INSTR_new.zip
lot's more $$
Capt Bj, have done the research... Interfaces are a headache to get running right and more of a bother than they are worth. However you can find everything from car docking stations right down to a straight apple connector with raw ends (w/ breakout schematics) and a wide variety of connection cables in between that are used with the headunit straight in aux port. FYI, among audiofiles the best audio is found through the apple connector, not the earbud jack. I am unsure about connecting the Apple connector power leads directly to a 12VDC source and possibly creating a noisy ground loop... Thanks for your suggestion though.
groundloops are a very common problem on MINI - anytime sound and charging both connected it seems (search groundloop)
you'll be wanting an isolation transformer if you go this route I believe
In my R50 I located the aux jack on the right side of the Euro Parcel Shelf, which worked out great.
And if you need help with the aux-in, I'll be at Van Damme in May for ab diving.
Navigation & Audio USB stick keeps repeating same folder
Wombat Pie
Navigation/Audio
Oct 5, 2015 08:00 PM
Oct 1, 2015 12:13 PM
Tires, Wheels & Brakes
Oct 1, 2015 08:55 AM
