Navigation & Audio Anyone know how to access back of stereo?
Old Jul 15, 2012 | 04:19 PM
MC2005s's Avatar
MC2005s
I have a factory ipod setup in my r53. The car is an 05, so the cord is old and doesn't charge with my iphone4....I'm going on a 9 hour ride tomorrow and always use spotify on my iphone while plugged in, but the batt will die since the charger "isn't compatible" or whatever....I believe I just need to plug a newer cord in and run it through the glovebox but I have no idea how. thanks!
Old Jul 15, 2012 | 06:11 PM
Eric_Rowland's Avatar
Eric_Rowland
See instructions here: http://www.gbmini.net/wp/2005/04/new..._installation/
Old Jul 15, 2012 | 07:14 PM
rkw's Avatar
rkw
Are you just playing Spotify through an aux input? I wouldn't have thought it was possible to play Spotify through a 1st gen factory iPod adapter. The cable would run to an adapter box, which has another cable running to the headunit. I'm not sure where the adapter box is usually placed (somewhere behind the stereo or dash).
In an 05, you don't have to completely remove the downtubes:
  1. Remove the torx screws (2 on each side) on the downtubes of the center console stack.
  2. Pull each downtube down about an inch, releasing its top from where it is inserted into the dash
  3. At this point, you can spread the tops of the downtubes apart and expose the mounting screws for the center stack components
This photo courtesy of GBMINI/Ian Cull:
Old Jul 23, 2012 | 07:41 AM
Cooped_Up's Avatar
Cooped_Up
I'm also in need of an aux cord installation. So after doing the above ^^, I should simply be able to plug in an aux cord and run it through the glove box correct?
Old Jul 23, 2012 | 10:02 AM
rkw's Avatar
rkw
If your hands aren't too large, it's possible to plug in the aux cable without pulling the headunit. Some people have been successful by simply reaching around to the back of the stereo on the left side. It should be plugged in at the lower left corner. If you can reach in and feel where it goes, you might try it.
Mount the other end of the aux cord anywhere, according to your preference. I didn't want mine in the glovebox and put it in the center console storage area.
Old Jul 23, 2012 | 10:18 AM
Cooped_Up's Avatar
Cooped_Up
I know I didn't specify earlier but I have an '05 mini coop...idk if that matters. My car is supposed to be aux port capable or something along those lines (the original custom order details/owners manual state that). So it should have this accessibility in the picture you posted, correct?
Old Jul 23, 2012 | 11:40 AM
Eric_Rowland
Yes the head unit on your car supports the Aux-in functionality (early '02 models didn't.) The interiors are the same, so yes, you can either plug the aux in with the head unit installed, or pull the head unit then plug it in.
Old Jul 23, 2012 | 11:57 AM
Cooped_Up's Avatar
Cooped_Up
Thanks fellas!
Old Jul 23, 2012 | 12:46 PM
OldGameFreaK's Avatar
OldGameFreaK
try one of these....it might solve your charging issue.
http://www.scosche.com/consumer-tech/product/1667
woodstudio
Mar 15, 2020 08:28 AM
surfblue
Oct 24, 2018 01:20 AM
Toolman
Jan 20, 2016 06:50 AM
Aug 12, 2015 01:24 PM
