Navigation & Audio dumb question. hk stereo aux in....?
Old Apr 15, 2012 | 09:52 AM
inkspot1967's Avatar
inkspot1967
dumb question. hk stereo aux in....? still not working ????
I have a 2008 mcs with the hk stereo and aux in.
Ok here we go how do i use it?
I plug in my phone play my music but nothing comes thru. I hit the mode button and all it does is switch between cd and radio. The steering wheel controls dont do anything either.
Old Apr 15, 2012 | 10:02 AM
danthemanohhyea's Avatar
danthemanohhyea
On mine I have to press the mode button twice quickly for it to switch to AUX when I'm listening to the radio.
It took me a while to figure it out when I first installed the kit.
Hope that helps!
Old Apr 15, 2012 | 10:22 AM
inkspot1967
Thx i will try that
Old Apr 15, 2012 | 10:38 AM
inkspot1967
I tryed that and nothing
Old Apr 15, 2012 | 01:47 PM
inkspot1967
I pulled my radio and aux in switch out all is plugged in but doesnt work. Maybe bad switch or is there a fuse for the wheel controls they dont do anything?
Old Apr 16, 2012 | 09:04 AM
danthemanohhyea
I'm not sure about a fuse for it all. I can't imagine that the steering wheel buttons would need fuses as I'd imagine they're just signal wires with no real power running through them requiring fusing.
Sorry I can't be more help, I don't know a ton about the system on these cars yet.
Old Apr 21, 2012 | 03:13 PM
inkspot1967
ok i still cant get it to work.
Old Apr 21, 2012 | 08:43 PM
Meister's Avatar
Meister
My iPhone would not play through the factory head unit unless I used a y-cable plugged in to both the USB AND the aux input connectors. Then everything worked great. Luckily for me the previous owner left a y-cable in the car when he traded it in.
Old Apr 22, 2012 | 05:01 AM
inkspot1967
i dont have the usb in mine so thats not it.
starting to really hate the HK stereo....
Old Apr 22, 2012 | 06:52 PM
RC CAR's Avatar
RC CAR
you should try checking that the wires from the aux in are in the right places in the connector on the back of the head unit. also ik that if you have a case on your phone or ipod that sometimes the plug wont go in far enough so try without the case.
just a though hope it works
Old Apr 23, 2012 | 05:46 AM
inkspot1967
Thx i pulled the radio out and its plugged in and no case on my evo 3d phone so its plugged in all the way and i tryed another cord also still nothing. Maybe its the aux plug itself that dont work sucks if i buy another and still does it but maybe only thing else to try
Old Apr 23, 2012 | 02:41 PM
Capt_bj's Avatar
Capt_bj
is your device also connected to a charger? there is a well documented ground loop issue if you use the aux in and a charger ... but you can get an inexpensive "box" to eliminate the problem
search ground loop
have you tried a different device - iPOD certainly works can you run a test with one?
Old Apr 23, 2012 | 03:07 PM
inkspot1967
No charger just my evo phone i will try a iphone on it.
Old Apr 23, 2012 | 04:21 PM
inkspot1967
Iphone doesnt work either.
Old Apr 23, 2012 | 09:06 PM
rkw's Avatar
rkw
When you cycle the mode button, AUX should appear even if you have nothing plugged in. There is something wrong with either the aux cable or the headunit. If the steering wheel buttons also don't work, the evidence points more towards the headunit. I would first try pulling the headunit out and unplug/replug all the connectors in back, in case some pins aren't making good contact.
BTW, it has nothing to do with the HK. The base stereo and HK both use the same headunit.
The car is a 2008 1st gen convertible. No USB option or Y cable.
Old Apr 24, 2012 | 04:13 AM
inkspot1967
thx i tryed unplugging and plugging back in everything when i pulled the HU out. seems maybe HU since aux doesnt come up at all when i cycle the mode button.
i wish i could replace the head unit for a alpine i have laying around but from what i have read on here is not possible without replacing everything else, man this really sucks.
Old Apr 24, 2012 | 09:12 AM
rkw's Avatar
rkw
The aux problem could be caused by a faulty aux cable. It has a small circuit that the headunit detects before it enables aux mode. I've seen a few threads where the cable was the problem and it worked after replacement. However, the unresponsive steering wheel controls indicate there might be other issues with the headunit.
You can use an aftermarket headunit by using an adapter called the HK Enabler, sold at this UK vendor: http://www.newministuff.com/new/shop...uctshow&id=116. The inventor Ian Cull (member GBMINI here) chronicled its development in his blog: http://www.gbmini.net/wp/2004/06/min...roductionized/
Old Apr 24, 2012 | 12:19 PM
inkspot1967
thx i tryed 3 different ones nothing worked. my steering wheel controls work for volume up and down and switches radio station and cd tracks but the phone and the r/t buttons do nothing.
i will look into that that would be nice if i cane get one of those and switch the radio for my alpine.
Old Apr 24, 2012 | 02:11 PM
rkw's Avatar
rkw
That's normal. The phone buttons are there whether or not the car has bluetooth. Factory installed bluetooth was not available during the 1st generation MINI. There was only a very expensive OEM Bluetooth kit installed by the dealer and almost nobody got it.
Old Apr 24, 2012 | 03:47 PM
inkspot1967
ah thx again
RobbyD
Jan 29, 2019 01:22 PM
rikaro
Nov 24, 2015 02:05 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Norton70
Sep 11, 2015 12:16 PM
