Navigation & Audio Radio Signal with Cleansweap etc
Hi
wonder if somone can help me. I have got quite annoying static radio signal and i can ony get 1 radio channel on my radio. Anyone know where the radio signal cable runs from in the car and if the HiFi amplifier has a port on the plug end that gives the arieal power?
help is really apprecieted as am running out of CDs!!
Cheers
Cheers
A little more info might help us help you.
What year is your car?
Where do you live? city level not you actual address.
It sounds as if you can play CD's with all channels playing music? Yes/No
It sounds as if you are saying that the radio can only play thru one channel? Left or Right.
You stated you have the HiFi system So you have tweeters in the A-Pillars? yes/no
By ariel power exactly what do you mean?
The antenna does not have power to it from the amp.
I can help you better if I have these answers.
Car is 2008 R56 S
Im from the UK, Manchester
All channels (only using front speakers component speakers which are 6.5" woofer and tweeter in a pillars which are JL Audio C5)
Radio comes from both channels (currenlty the JL HD Amp is bridged with a 10W3 sub and the components are running channel 1 and 2 on the amp)
I did have the HiFi system but this inc the amp and speakers were taken out
Is there an amplifier for the arial which requires power that i may have snagged off?
Car is 2008 R56 S
Hi
Cheers
Cheers
Yes it definatelly sound as if you may have disconnected the antenna lead or power to the antenna amp.
R50/53 Help please.. Odd issue.
PsychoRallye
21
Feb 17, 2019 06:08 AM
Alpha Motoring
Oct 1, 2015 10:30 AM
