Navigation & Audio R56 Speaker Replacement Q
Old Mar 3, 2008 | 08:40 PM
sunshine22's Avatar
sunshine22
Forgive me if this is covered elsewhere, but I am pretty close to swapping out the 6.5 inch speakers in the door.
One Q, which is the positive/negative wires? My new speakers are labeled, but I am not sure which wire is which. Before I cut and solder, I want to get it right.
Also, how do I get the covers off the smaller speakers in the door? Do I need to do something special w/ the mirror control? Thanks.
Old Mar 3, 2008 | 09:43 PM
DyeLooper's Avatar
DyeLooper
Check my gallery. Also, use a battery and do the battery test. One wire to the pos, one to the neg. If the cone bounces inward, that is wrong. Switch the wires and the cone should bounce outward, this is correct.
Old Mar 4, 2008 | 07:53 AM
condor27596's Avatar
condor27596
You can go to harbor freight and get a multimeter
the cheapest one for about $4. Then touch
the wires and it will show + and - .
It also comes in handy for testing the wires in your house
like for replacement of X Y Z to see if the power is off
"really", or REALLY. BZZZZZZZZZ OW BLANKETY BLANK!
Old Mar 4, 2008 | 11:01 AM
sunshine22's Avatar
sunshine22
Thanks. How do I remove the cover over the 3.5 inch speakers? Any special tricks to deal w/ the mirror control.
Old Mar 4, 2008 | 11:32 AM
Robin Casady's Avatar
Robin Casady
https://www.northamericanmotoring.co...3&postcount=83
IIRC, they just pull off.
Old Mar 4, 2008 | 11:33 AM
Robin Casady
Patience. Look at it carefully as you take it apart. There is a certain way it goes together. Once you figure out the logic of it, reassembly becomes easier.
Old Mar 4, 2008 | 11:54 AM
sunshine22's Avatar
sunshine22
Do I take off the mirror control b/f I pull off the speaker cover. The mirror control comes out of the speaker cover and it looks like if I pull off the cover first, it will break the control.
But that said, I don't see any way to take off the mirror control first.
Old Mar 4, 2008 | 12:51 PM
lacning74's Avatar
lacning74
I just pulled the cover and it came out together with the mirror control in place. Just be gentle, since the mirror control wiring will be tethering it.
Old Mar 6, 2008 | 06:13 AM
Primus's Avatar
Primus
You can pull out the mirror control first as a whole. It is clipped like the light holder in the bottom. There's no need to disassemble it. Pop it up gently with a screwdriver at the lower edge. Then detach the connection.
theblackfalcon
Oct 11, 2015 09:49 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
makg
Aug 21, 2015 02:49 AM
OutMotoring
Aug 6, 2015 09:32 AM
