Navigation & Audio Which Kuda Add-On for my Garmin Nuvi 650 GPS
Old Dec 16, 2007 | 08:13 AM
celica414's Avatar
celica414
I've searched the forums and learned that really my best option to mount my Garmin 650 is using the Kuda mount (item # 292445)...my questions are:
1. Which Garmin Kuda Add-on is better, what's the difference?
This One or This One
2. What else, if anything, do I need to purchase to mount my GPS?
Thanks for the help!
Old Dec 16, 2007 | 01:09 PM
lacning74's Avatar
lacning74
I had the same questions. It was a coin toss. I ended up getting the first one (CNM21) thinking that it looked like it had an adjustable hinge even though there reallly is no reason to. Anyway, it is not adjustable. In retrospect, I like the cleaner look of the second one (CNM22). Here's mine and bjacobso's install pics to compare (sorry, mine is with the Garmin mount on but you can still see the difference of the base):
Old Dec 16, 2007 | 02:10 PM
celica414's Avatar
celica414
hmm, interesting that they would make two add-ons without any real differences...thanks for your input
Old Dec 17, 2007 | 04:15 PM
crump500's Avatar
crump500
I think I would go with the second one the (CNM22) also. The reason being is appears to have a cover to hide the mounting screws. There is a close up with a MINI on the KUDA site if you click the enlarge button below the picture of the CNM22, Good Luck...
Old Dec 17, 2007 | 05:58 PM
celica414's Avatar
celica414
i wonder how difficult it would be to fabricate a custom flip down panel to mount where the top mood lights go...hmmm
Old Dec 17, 2007 | 06:36 PM
Minidrivr's Avatar
Minidrivr
There's a lot of room in there...anything is possible if you fabricate mounts and brackets to hold it all.
Old Dec 21, 2007 | 04:30 PM
celica414's Avatar
celica414
ok, so i'm going to place the Kuda mount order...what else will i need to order to hide the wires?
Old Dec 21, 2007 | 05:06 PM
Minidrivr's Avatar
Minidrivr
Do you have the Nav with your car? Kuda makes a different one for cars with OEM Nav, which isn't listed on their website.
Old Dec 21, 2007 | 05:10 PM
celica414's Avatar
celica414
no, i don't have the factory navigation
Old Dec 21, 2007 | 06:25 PM
Minidrivr's Avatar
Minidrivr
The Kuda mount you ordered will fit just fine then.
Old Dec 25, 2007 | 09:20 AM
celica414's Avatar
celica414
I got the kuda mount and add-on in the mail today!!!!! Should I screw the add-on directly in the center of the mount? This one appears to be placed higher than the pic above by lacning74 http://img45.imageshack.us/img45/8513/80354492rl4.jpg
Old Dec 25, 2007 | 02:41 PM
911Fan's Avatar
911Fan
1. How does the Kuda mount attach to the dash?
2. How do you like the 650 -- Pros & Cons?
3. Thanks.
Old Dec 25, 2007 | 02:50 PM
lacning74's Avatar
lacning74
Center works for me. I guess some people want it higher to clear the steering wheel. My OCD forced me to mount dead center. If you want, play around with some double-sided tape mounting your Garmin before you commit.
Old Dec 25, 2007 | 02:52 PM
lacning74's Avatar
lacning74
Check out unixgal's post. This is my install.
Old Dec 25, 2007 | 03:05 PM
celica414's Avatar
celica414
I've heard great things about it, i'll let you know what i think of it once i install it!
Old Dec 25, 2007 | 07:21 PM
celica414's Avatar
celica414
has anyone tried to cut the bottom of the kuda mount to fit this wire through?
Old Dec 25, 2007 | 08:12 PM
lacning74's Avatar
lacning74
Cool idea, but it would be tricky where to run the cord afterwards especially since it is kind of thick. Also the ends are very bulky.
Old Jan 6, 2008 | 10:13 AM
T-Horn67's Avatar
T-Horn67
I ordered the CNM22 and mounted it a little higher. I then drilled a hole below it to feed the power wire through. I left about 1.5 inches of wire with USB connector on it. Looks very clean.
Old Jan 6, 2008 | 10:31 AM
celica414's Avatar
celica414
I'm still debating whether to do this, do you have any pics? I'd love to see how yours came out....
kevinlhr310
Apr 25, 2018 05:08 AM
minimofo
Dec 26, 2015 12:03 PM
vetsvette
Oct 2, 2015 07:09 PM
minimofo
Sep 30, 2015 12:26 AM
TurboMike
New York/New England
Sep 28, 2015 08:12 PM
