Navigation & Audio Bluetooth pairing with Sprint Motorola Q?
Old Dec 14, 2007 | 03:00 PM
Kaidaddy's Avatar
Kaidaddy
Has anyone succeeded in pairing their Mini's bluetooth with a Sprint Motorola Q? I can successfully pair the phone wit the Mini - ie. I get through the step of entering a passkey into the radio interface. However, after that, the Mini does not recognize that the phone is paired. On my Motorola, I can see the Mini's bluetooth connection as active.
If anyone has encountered this situation with a different model phone, and was able to solve it, I would appreciate any suggestions. Thanks!
Old Dec 15, 2007 | 02:51 PM
cob666's Avatar
cob666
My Verizon Moto Q works in my MCS. The only feature I don't have is the voice dialing. If I use the buttons on the stereo I can find names and numbers but when trying to use voice dialing I'm told that there are no entries in the phone book.
Old Nov 21, 2011 | 04:08 PM
Eddyboi77's Avatar
Eddyboi77
Hate to revive an old thread, but I recently switched back to my old Motorola Q (w/ Verizon), and I was able to successfully pair the phone with the car, however none of my contacts are showing up in my phone book in the car. I can receive calls in the car, and make calls using either the phone or the digit dialing through the car, but still no contacts. I've tried sending my contacts from the phone via bluetooth to the car, but it hasn't worked. Any ideas??
Old Nov 22, 2011 | 12:04 PM
schatzy62's Avatar
schatzy62
Take a nice long drive it can sometimes take as much as 3-4 hours for the first transfer if you have a lot of contacts (100+)
Old Nov 22, 2011 | 01:31 PM
Eddyboi77's Avatar
Eddyboi77
Thanks for the tip, I've got 50-something contacts, however this is the 2nd day with the phone being paired to the MINI and still no success. Any more suggestions?
Old Nov 23, 2011 | 04:45 AM
schatzy62's Avatar
schatzy62
The first time 5-6 times I paired an old Motorola it did not take the 250+ contacts. It took 1 LONG ride to get it all there the first time.
The way it seems to work is that it starts new each time until all the contacts are saved in the car. Then after that it only takes in changes so the updates are much faster.
Old Nov 23, 2011 | 07:34 AM
Eddyboi77's Avatar
Eddyboi77
That makes sense, I'll keep trying! Thanks so much
Old Nov 23, 2011 | 09:54 AM
Minidrivr's Avatar
Minidrivr
You'll might try the voice dial setup in this thread.
https://www.northamericanmotoring.co...oice-dial.html
Back with the 07 models if the car didn't have Nav you had to program the voice dialing as detailed in the link above. With Nav and it would voice dial without any setup. With the newer system in todays cars I don't know if that's still true or not.
I noticed with a new iPhone 4S my 07 didn't voice dial the first day, but after that it voice dials as good as the old Razr it replaced, without any setup.
Suspension Products
Oct 1, 2015 11:14 AM
Alpha Motoring
Oct 1, 2015 10:30 AM
nshannon29
Sep 30, 2015 05:21 PM
BendersMINI
Sep 27, 2015 07:02 PM
