MTH Discussion (Archive) Have or interested in MTH software upgrades for your MINI? This is the place! Sponsored by MTH.
Is it worth adding to a JCW
Old Nov 10, 2005 | 09:05 AM
  #26
62Lincoln's Avatar
62Lincoln
DetroitSlim, thank you for sharing your info. I have an '05 JCW, and this is very interesting info. The a/f curve appears to indicate that you have a rich condition above 5,000 rpm that would yield more hp if leaned out. What do you think? Have you been able to share the a/f info with Tradiuz and MTH to see if they can lean it out? How was the a/f info gathered - do you have a header with a bung, or...?
Old Nov 10, 2005 | 10:48 AM
  #27
DetroitSlim's Avatar
DetroitSlim
I had the all my dyno data sent to the MTH guys in Germany, but haven't heard back yet.
The A/F was taking from the tail pipe.
Not sure what you mean by it running rich, the tuner file appears to run a bit leaner than the original JCW map above 4000 rpm.
I would have done back back runs, but the MTH guys on state you have to drive a few hundred miles for all the adaptive learning to kick in.
Old Nov 11, 2005 | 04:53 AM
  #28
Volker@MTH's Avatar
Volker@MTH
Problem with those same day dyno results is always the ECU. It needs to be re-set completely before you get accurate figures. I have to say it again – it can NOT be done through the speedo. You would need a dealer to do that for you. Otherwise it takes a few 100 miles in order for the ECU to fully adapt.
Btw, there is a new version of the tuner file available (vt_7). An official announcement should be posted by MTH-USA / Pat soon. Existing customers will get the update for free.
Old Nov 11, 2005 | 04:59 AM
  #29
Volker@MTH's Avatar
Volker@MTH
Accurate A/F figures can only be gathered by installing a LSU sensor right in front of the pre-cat. Everything else is fine for emission control, but does not provide detailed data to work with. Fiddling with A/F is tricky and can result in major engine problems (but I am sure you knew that already :smile: ) .
Old Nov 11, 2005 | 05:58 AM
  #30
XTREEM's Avatar
XTREEM
Does this new version fix our ongoing flat spot problem?
Old Nov 11, 2005 | 06:18 AM
  #31
tradiuz's Avatar
tradiuz
MTH Specialist
Thats the reason for the new version.
Old Nov 11, 2005 | 07:15 AM
  #32
XTREEM's Avatar
XTREEM
Is this a proven fix or a attempt? Can you share any details on what has been changed?
Old Nov 11, 2005 | 07:42 AM
  #33
XTREEM's Avatar
XTREEM
If we have a header installed where would we need the LSU sensor reading from? just in front of the cat?
John.
Old Nov 11, 2005 | 08:20 AM
  #34
DetroitSlim
Thanks for the information. I will get with Simon to request a new version for my car.
John
Old Nov 11, 2005 | 09:07 AM
  #35
tradiuz's Avatar
tradiuz
MTH Specialist
Pre-Cat (where the first O2 sensor is). The post Cat O2 sensor is just for checking cat efficiency and emessions.
There was a great discussion on Wideband O2 sensors (LSU) and how some have a Wideband output with a narrowband so they could be put in place of a stock O2 without adding a bung.
Old Nov 11, 2005 | 09:21 AM
  #36
Cooper_Si's Avatar
Cooper_Si
This IS a proven fix....
Old Dec 29, 2005 | 01:49 AM
  #37
pyugala's Avatar
pyugala
See my dyno result here https://www.northamericanmotoring.co...ad.php?t=55696 , for before and after back to back runs.
theblackfalcon
Oct 11, 2015 09:49 AM
bjcarter2
Aug 31, 2015 04:03 PM
SunnySideUp
11
Aug 26, 2015 06:42 AM
blackie
Aug 23, 2015 08:44 PM
minipopkart
Aug 13, 2015 05:22 AM
