Mini/MINI BUILDS Showcase your Build Talents.
Had Mini for 4 Months already spent 3k in upgrades!!!
Old May 5, 2019 | 01:19 PM
  #26
TVPostSound's Avatar
TVPostSound
When you lower a car with CV axles after it has had some miles on it, you will get a wobble.
The inner CV joint buckets have developed a wear pattern, when lowering the car, the CV joint moves in slightly.
When accelerating (front end comes up) the CV joint tramlines inside the bucket to its original worn position (pre lowered) and back.
The joint really doesn't wobble, the inner bucket does. As its bolted to the transaxle, its the engine that vibrates.
Getting a stiffer "dog bone" engine mount will minimize it.
Its a common issue:
search "cv wobble lowered car"
Old May 5, 2019 | 06:08 PM
  #27
copajoe's Avatar
copajoe
3K and still on stock rims! Nice color choice
Old May 5, 2019 | 08:47 PM
  #28
nosben's Avatar
nosben
this one is less than 3k.
Armaspeed mini R60 carbon fiber intake
Old May 6, 2019 | 10:08 AM
  #29
RoseCityMini's Avatar
RoseCityMini
Its a common issue:
This is what I thought may be the issue, something with the CV joints. Thanks for the response!!! Do you know where I could get these engine mounts? Cost?
Old May 6, 2019 | 10:09 AM
  #30
RoseCityMini
Went for performance first, I really like your rims though. What are they? Size? Did you need to do anything else suspension wise to make them work?
Old May 6, 2019 | 10:14 AM
  #31
RoseCityMini
Its a common issue:
Also is this putting any unwated stress on those joints?
Old May 6, 2019 | 12:01 PM
  #32
oldbrokenwind's Avatar
oldbrokenwind
Several years ago NM Eng'g sold stiffer inserts for $60. Gotta be careful 'cause inserts are different for a couple of the gen II models. I'll sell my complete torque arm with inserts and include shipping to the Portland area for $40. Inserts were only used for a few months.
Old May 6, 2019 | 01:37 PM
  #33
RoseCityMini
i have a f56???
Old May 6, 2019 | 01:56 PM
  #34
oldbrokenwind
Nope, per RealOEM, this part isn't designed for the F56. Doesn't mean it won't fit, but not worth the gamble. This is a pretty popular upgrade --- you should shop around the various NAM vendors for what's available. Be advised that this mod can create a pretty stiff ride, depending on brand. My current version, Vibra-Technics, even introduced center rear view mirror vibration.
Old May 6, 2019 | 02:07 PM
  #35
RoseCityMini
Is the current state of my car bad for the CV joints?
Old May 6, 2019 | 02:44 PM
  #36
oldbrokenwind
Its a common issue:
Per TVPostSound, it's the CV joints causing the vibration. It's the vibration caused by the "different" wear pattern that's gonna cause a bigger problem for everything else. It can be eliminated by going back to OEM height springs, or replacing axles. Minimizing isn't the same as eliminating. How badly do you want the look / feel of a lowered car?
I recently replaced a CV boot --- one tore and started leaking. PITA and messy to replace just the boot, but it came apart easy enough. Just needed special tools for the boot clamps. Maybe take one or both of yours apart, clean and inspect it for the wear pattern described?
Old May 6, 2019 | 03:13 PM
  #37
RoseCityMini
I like the look of the car lowered but it was costly to install. And now with these headaches Im feeling like it wasnt worth it. Axles? you mean just replacing with new stock axles? It would probably run me around $600 to put the OEM springs back on
Old May 6, 2019 | 04:26 PM
  #38
oldbrokenwind
There are aftermarket axles, some probably less expensive than OEM, and others for hi perf cars. Sounds like you didn't save the OEM springs --- maybe try a wrecking yard, or somebody that didn't scrap theirs? I only upgraded shocks, not springs --- keeping the OEM "sleeper" look.
Best of luck ---
Old May 6, 2019 | 04:27 PM
  #39
RoseCityMini
Best of luck ---
I still have the springs but it cost $600 to install the new ones, so assuming they would charge around the same to put old back on
Old May 7, 2019 | 04:12 PM
  #40
Altecfenix's Avatar
Altecfenix
By the dame logic of the wobble being caused by wear; could it be fixed by wear too?
Also; is this wobble enough to actually warranty any action? Does it wobble so much that it harms the driving performance?
I'd like to drive your car dude, see what you're feeling.
Old May 13, 2019 | 04:28 PM
  #41
TVPostSound
It will fix itself by wear, I don't notice it anymore.
Old May 13, 2019 | 04:32 PM
  #42
TVPostSound
Like a bent wheel would feel in the back, but in the front, no steering wheel wobble.
Only on low speed acceleration.
Old Jul 25, 2019 | 05:47 PM
  #43
madmix's Avatar
madmix
Give it some time and I bet it goes away. If it won't go away after a few weeks, let's say, then it'll probably be something to look into. I'm not sure how the springs would cause a kind of wobble, I'd wager on installation if anything, but crazier things have happened.
I'd be curious to drive it myself and feel what you're feeling.
so I put Craven Speed springs on my JCW and I feel the exact same wheel wobble at 15 miles per hour, front right side.
Old Aug 2, 2019 | 08:25 AM
  #44
vetsvette's Avatar
vetsvette
Moderator
How many miles did you have on the car with stock suspension springs?
Str8Grizzly
Mar 14, 2013 06:01 PM
sekhmet101
Jul 13, 2010 08:24 PM
amancara
R55 :: Clubman Talk (2008+)
27
May 5, 2009 04:20 PM
Maxicooper
DC Metro MINIs (Archive)
130
Dec 11, 2008 03:25 AM
Trippy
Sep 26, 2003 05:52 AM
