Drivetrain Got my custom exhaust done today!
Well after having the car for a little over a week now it was time for some major modding to happen, the exhaust! A couple weeks ago the local Mini dealership had an official unveiling of the R56 and I met a fellow NAM member who told me about this exhaust shop called PF&E and the thing that was funny was the place was right around the block from my work and I didn't even know it and I've been there for 10+ years, don't know how long he's been there but its atleast 6 years. Anyways here's what was done:
-re-used the stock flexpipe because he liked the design
-removed the second cat and resonater
-removed the rest of the exhaust completely
-added 2.5" T304 stainless piping all the way back
-added a polished stainless steel Magnaflow muffler
-added a polished Pypes flattened out oval tip
Here's a pic from their website of the tip
Sorry, but this is the best pic they've got of it and it doesn't do it any justice because from day one I envisioned a single tip in this particular style, so for me it was one way to go, that way
Now I'm sure you wondering about the sound, well let me try and try and sum it for you guys....AWESOME!!! It has a deep burble when its going down the road and at idle its got just enough which is fine for most. Now I will say its loud enough that some would want to tone it down a bit and that easy to achieve because the owner of the exhaust shop (who actually handled this job for me) said you could add a bullet muffler to act as a resonater and it would quiet it down. I'm not going that route one bit because I really like how the car sounds now, its got REAL attitude and some real pull! I know its seat of the pants but this car really honks a bit more now which isn't a bad thing! Speaking of that, I know the MCS isn't about drag racing or anything but my previous car, a 2005 Crossfire which actually had a Magnaflow muffler only ran a 14.8@94 mph and my MCS feels WAAAAAAAAAAAAAAAAAY faster than my Crossfire, I'd bet any money on that. In closing I must say that if your thinking about an exhaust upgrade look around and find yourself a good exhaust guy and have at it
*UPDATE*
It appears that my clubphoto is now "under construstion", so my pics will be up ASAP, but as far as a sound clip goes....Ryan
Sounds like a great quality setup- was the system mandrel or crush bent?
Although this is a turbo'd vehicle, is there any detriment in going with 3" diameter piping since the engine displacement is so low?
Exhaust systems for turbocharged engines are relatively straightforward compared to naturally aspirated or supercharged engines. The turbo is the biggest restriction apart from the catalytic converter. The turbine damps the exhaust gas pulses and converts them into rotational motion. This ruins just about any chance to build a tuned secondary or impliment a scavenger box. Because the turbine messes up the exhaust flow so much, the main priorities are to convert the turbine exhaust flow from radial to laminar flow, and to keep the turbo-back exhaust restriction to an absolute minimum. The engine displacement doesn't play a part in selecting tubing diameter as much as peak horsepower [aka maximum flow-rate] does.
HTH,
Ryan
HTH,
Ryan
That's the best layman's description of Turbo exhaust tuning I've heard yet.
HTH,
Ryan
HTH,
Ryan
Originally Posted by karlInSanDiego
Hey Nerd! Did you just call me a name???
If your name is Laminar Flow then please accept my apologies!
I'm glad that my description was helpful!
Originally Posted by ygblat
So, ideally, the wider (and smoother) the better so as to decrease backpressure as much as possible? Also, is there a diminished rate or return after a certain diameter? Finally, would it make sense to gradually increase diameter throughout the exhaust, creating a cone-shaped pipe (speaking from an ideal standpoint and ignoring the horrendous real-world difficulties one would incur in order to execute something like this)? Sorry to burden you with these musings.
Cheers!
Ryan [the nerd]
In the short time I've been around Ryan I think my automotive IQ has gone up a bit, just listening to him
Our local rock radio jockeys in the morning, Drew and Mike, use this Homer drop sometimes and it fits best here with Ryan's use of words, check it out...
Homer's voice..."can you repeat the thiiiing you said about things?"
Our local rock radio jockeys in the morning, Drew and Mike, use this Homer drop sometimes and it fits best here with Ryan's use of words, check it out...Homer's voice..."can you repeat the thiiiing you said about things?"
JPMontes3
Aug 24, 2015 07:15 AM
jrezzo
Aug 9, 2015 10:32 PM
