R56 auto trans lag
Old Apr 15, 2007 | 06:17 PM
jerrypare's Avatar
jerrypare
auto trans lag
I have had my 07 Cooper with Automatic for 6 weeks and 1500 miles. I have a real issue with the tranny not shifting properly after turning a corner. Does not downshift correctly, big lag time before it downshifts. If you step on the gas to force it to downshift, it goes into a lower gear than what it should and tachs out the engine. Took it to the dealer and they said that it was an adaptive tranny that would learn my driving habits and would take a while to program itself. They have got to do better than that, very weak explanation in my opinion. I have had similar problems with another car, and the manufacturer had to update the progamming on the tranny. Any one else experiencing this problem.
Old Apr 15, 2007 | 06:42 PM
Gold88's Avatar
Gold88
No, sorry. There are some times when I do have a lag turning a corner. It usually happens at the same spot - there is a dip in the road when turning and stepping on the gas lags until I straighten up, but I'm sure it is the dsc kicking in. Also, it usually only happens at slow speeds going less than 15 mph.
I haven't had a problem with the 'kick-down', but I haven't put the pedal to the floor yet either. After driving it today I was actually quite impressed how it responded as I'm coming out of driving it in granny mode.
Old Apr 15, 2007 | 09:37 PM
Ken Cooper's Avatar
Ken Cooper
[quote=Gold88;1477632]No, sorry. There are some times when I do have a lag turning a corner. It usually happens at the same spot - there is a dip in the road when turning and stepping on the gas lags until I straighten up, but I'm sure it is the dsc kicking in. Also, it usually only happens at slow speeds going less than 15 mph.
[quote]
Sounds more like traction control kiicking in to me.
Old Apr 16, 2007 | 12:13 AM
Chuck W.'s Avatar
Chuck W.
I am looking at ordering an auto MCS due to the Los Angeles traffic. Does the S have the same problem?
Old Apr 16, 2007 | 12:38 AM
j0dan's Avatar
j0dan
I'm considering an auto as well. But I think the no LSD option will kill that plan.
Curious how good it is driving with the paddles.
Old Apr 16, 2007 | 08:08 AM
jerrypare's Avatar
jerrypare
Shifting with the paddles works great. FWIW, I don't have DSC or LSD. I really notice the problem when I turn a corner that goes immediately up hill. Dealer has acknowledged the problem because they were able to duplicate it themselves. But, they and BMW have no solution.
Old Apr 16, 2007 | 08:20 AM
DyeLooper's Avatar
DyeLooper
Auto MCS here, after 22 yrs of manual tranny, I had to have auto this time, Love it and have no complaints.
Old Apr 16, 2007 | 08:59 AM
BrewSwapGuy's Avatar
BrewSwapGuy
Formerly PassatDoTd
I have the R53 MCS automatic. The transmissions are the same between the R53 and R56 when it comes to the automatic.
I had the exact same problems as Jerrypare described. There's nothing that can be done about it unfortunately. It's the software and the way they have it set up. It will not learn to not do that.
The solution for me, which won't work for Jerry, was to drive around in sport drive (shifter kicked over in the drive slot). It stays in gears longer so there isn't as much a chance for the downshift issues. It also got better once I put a pulley and exhaust on there.
Old Apr 16, 2007 | 09:09 AM
Edge's Avatar
Edge
AdMINIstrator
My solution is a manual tranny.
(sorry, couldn't resist... I realize that manual is not an option for everyone... but I love the total control it gives!)
Old Apr 16, 2007 | 10:19 AM
eVal's Avatar
eVal
The paddles are your friend
Since I drive in manual mode shifting at will most of the time I don't have this problem - the other % of the time I am in sport mode and I have noticed that in this and other BMW manumatics the auto modes do adapt after you drive in manual mode for awhile and reflect more aggressive shifting.
PS: I guess if it is predictable behavior and you do want to stay in auto mode you can always just flick the paddle for a downshift at that point without going into manual mode - the auto will resume shifting that way.
cub4bearindiana
Oct 2, 2015 09:45 AM
Oct 1, 2015 12:13 PM
Sailorlite
Oct 1, 2015 06:46 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
kevinlhr310
Sep 27, 2015 02:31 PM
