injector failure?
Old Jan 6, 2007 | 07:57 AM
herbie hind's Avatar
herbie hind
injector failure?
anyone had p0313 along with a specific cyl. misfire? p 0313 is low fuel and is specific to cyl. 4 misfire . where does the car determine a low fuel condition exists? o2 sensor? if so can i assume a bad injector?
Old Jan 6, 2007 | 07:59 AM
herbie hind
also ; can these injectors be cleaned? remove screen ,that type of thing, or are they throw aways?
Old Jan 6, 2007 | 08:24 AM
Hound_va's Avatar
Hound_va
How about running a couple of tanks of gas with fuel system cleaner/injector cleaner thru it, clear the code and then see if it comes back?
Old Jan 6, 2007 | 08:38 AM
NMgokart's Avatar
NMgokart
May be a clogged injector; try the cleaner method first and work your way up from there.
Old Jan 6, 2007 | 09:03 AM
herbie hind
tried all that for a while now. was waiting for it to become steady rather than intermittent. turns out it was my screamin' deamon coil . swapped the plugs;nothin' ; swapped the deamon and off and runnin' . so maybe #4 is the one the computer spits out when there's a problem with that halfe of the coil. don't know . still don't understand the low fuel thing. i've been adding injector cleaner for about 5 tanks now.
Old Jan 6, 2007 | 09:24 AM
NMgokart's Avatar
NMgokart
Goes to show that the codes aren't always that helpful. Glad you found the problem.
Old Jan 6, 2007 | 09:28 AM
Dr Obnxs's Avatar
Dr Obnxs
Injectors get dirty...
but rarely fail. The seals can dry and you can get a vacuum leak as well. For cleaning them, I sent mine off to Witch Hunter Performance (I think it's www.witchhunter.com) for cleaning and flow testing. They replaced the seals and the intake filters, and ultrasonically clean the pintel/seal while squirting stuff through them. Then they flow test them. Mine came back matching to 1.1% high to low. I think it was $60, including shipping.
Matt
Old Jan 6, 2007 | 01:31 PM
herbie hind
Matt
thx very much doc i WILL do this. 60 bucks is cheap for all they did.
Old Jan 7, 2007 | 09:44 AM
SRTech's Avatar
SRTech
Follow the wiring harness for the injectors and unplug and clean the connectors in the harness. I had a car with this same problem and just unplugging and reconnecting did the job. Good luck.
Steve
IQRaceworks
53
Jun 28, 2024 07:29 AM
NYMADMINI
Dec 14, 2016 02:33 PM
randeez
Oct 5, 2015 09:23 AM
WhinyR53
Sep 30, 2015 07:36 AM
dutchhome
Sep 30, 2015 07:17 AM
