Suspension springs or coil overs
Old Feb 27, 2003 | 12:15 PM
itsthesize's Avatar
itsthesize
Hi, I'm new to the board and would like to know the following. Assume cost not a factor.
1. springs or coilovers
2. MCS suspension adjustable????
3. To lower or not to lower with 17" & 18" wheels
Thanks in advance.
Old Feb 27, 2003 | 12:20 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
One important thing to remember about coilovers is that you MUST get the car corner balanced. If you don't, your handling is likely to be worse than stock. Imagine installing a refrigerator in your kitchen without adjusting the feet. I see alot of cars with coilovers that are "slammed". The owners have no idea that each wheel may be exerting wildly different amounts of force on the road.
Old Feb 27, 2003 | 12:50 PM
Morales's Avatar
Morales
>>Thanks in advance.
If cost is not a factor and you get the corner balancing, then I would:
1. Coilovers
2. Minimum rear swaybar - Madness (2 adjustments) or RDR (3 adjustments)
3. 18"
4. Rear adjustable control arms
5. P&D camber plates and strut brace (works of art)
Then you can come over to my place and let me test it out for you.
Old Feb 27, 2003 | 01:07 PM
Phobol's Avatar
Phobol
Pardo my ignorance, but what is P&D. (Planning and Design is what i know it stands for) :smile: Do you have pics? i want to see the "works of art"!!!
Old Feb 27, 2003 | 03:21 PM
jlm's Avatar
jlm
http://www.mini2.com/forum/showthrea...threadid=24041
I would post more here, but pics are too much trouble on this forum
Old Feb 27, 2003 | 05:13 PM
Morales's Avatar
Morales
You asked for it!!!
Old Feb 27, 2003 | 05:21 PM
Ryephile's Avatar
Ryephile
UHHHH! I just cheezed all over the monitior.
That caster/camber/strut brace is AWESOME looking
I also see that by design it cannot strenghten the chassis torsionally, only in lateral bending, which is better than nothing
Got a question: where do I get it, and how much does it cost?
Cheers,
Ryan
Old Feb 28, 2003 | 08:34 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
I had the P&D plates here, and will get them back when jlm sends them.
With all the snow, it's really put a damper on testing .
I also have the LEDAs, and will be installing them as well. Here's a tease pic (thanks dpayne1):
So, money no object:
Tubular swaybars from H-sport
LEDA coilovers
17" ultra lightweight wheels
Product and Design camber plates
Delrin or Poly bushings
Let me know if you have any other questions.
The camber plates should be here soon, and the whole package will be on the car by next week.
Randy
randy@mini-motorsport.com
Old Feb 28, 2003 | 08:36 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
>>Cheers,
>>Ryan
I'll be carrying the camber plates after evaluating them (as long as there aren't any unforseen issues with the plates themselves).
Pricing looks like $499 for the plates alone, and $599 with the plates and strut brace.
Randy
Old Feb 28, 2003 | 08:51 AM
andy@ross-tech.com
You DO have a set of scales, right?
Old Feb 28, 2003 | 08:53 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Duuuhhh
Old Feb 28, 2003 | 09:06 AM
itsthesize's Avatar
itsthesize
Thanks everyone for your input. I placed the order for my MCS last nite and hope to have it by early May. I live in the Chicago area and I don't really have any leads to people who have shops to fine tune these products if installed. Don't know if the dealer is "very " competent in these types of mods and tuning. Any leads in this area?
Thanks!
Old Feb 28, 2003 | 09:09 AM
aperez49's Avatar
aperez49
Hey Randy any clue in range of price for the LEDA's? They look gorgeous.
Old Feb 28, 2003 | 09:10 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Try Sol at Perfect Power in Libertyville. I'm not sure what the number is, but you should be able to get it through information.
Old Feb 28, 2003 | 09:13 AM
Ryephile's Avatar
Ryephile
Randy, thanks for the preliminary pricing info. 'nother Q: who makes/where get a set of scales, for shock/spring tuning? I'm gonna need a set as I get closer to finishing my '32 Roadster highboy project (I'm using Aldan coilovers, as of now)
Thanks,
Ryan
Old Feb 28, 2003 | 01:04 PM
chris@helix's Avatar
chris@helix
itsthesize,
The type of system that would be best for you, even with the $ no object idea, depends on what type of things you are going to do with your car. What type of driving are you looking to do with your MCS? Auto-x, track events? Is this car your daliy driver? There are a few different roads that you can go down, driving a MCS down any one of them is a lot of fun!
Old Feb 28, 2003 | 02:07 PM
chris@helix
Randy,
We have not had a chance to put a MCS on a set of scales yet, could you let me know what the cross weights ,with driver, on your car are. We are starting a project in the next two weeks and some scale info would be cool before the car gets here. Thanks for your help! Any dates on the Tour yet?
Old Feb 28, 2003 | 03:17 PM
jlm's Avatar
jlm
Randy's pricing for the plates is accurate; but I reserve the right to re-evaluate after we finalize production. So far, the only change from the photo is that the strut brace has to be lowered about 3/8" to clear the hood inside surface and this means it interferes with the computer cover. The cover is inexpensive, so we may offer a suitably modded replacement to package with the brace.
I have a set on my car and was able to set the camber from -1 to -3 degrees very smoothly and accurately; caster I left at factory, although there is +/- 1.5 degrees available from stock.
Randy will get his set next mid-week, anodized and with the brace.
Old Feb 28, 2003 | 07:50 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
LEDA Pricing:
Stage 1 $1410 Oil strut/custom valving, strutbody, spring rates
Stage 2 $2318 Gas strut/24 position bump and rebound adjustment/custom valving, strutbody, spring rates
Stage 3 $3536 Gas remote reservoir/24 position bump 24 position rebound (48 total), custom valving, spring rates
All stages can use Hyperco springs which have virtually no sag, allow corner balancing within 2%, and are included in the price for Stage 2 and 3. The kits include the aluminum hats and all hardware. Stage 1 Hypercos are an additional $80.
This kit is awesome. We custom design each set based on the type of driving you do, the particular weight and distribution of your car, and the ride height you wish to get in a 2" range. Because it is custom built per order, they do take 3 weeks to get. The system can be revalved, and any spring rate can be used.
I will be doing the full install and eval next week, so the units won't be officially available until they shake out.
Randy
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
W0TM8
Dec 19, 2019 07:50 AM
Da_jesus
Aug 25, 2015 04:20 PM
sabjcw
Aug 14, 2015 07:40 AM
ki7hy
Aug 12, 2015 07:07 PM
