Drivetrain Jcw Injectors With Dinan Stage 5 Software
i was wondering if i got jcw injectors if i they would work with my dinan stage 5 software...the software is design for the boost kit..so they must move the fuel ratio...i just dont know if they changed anything on the injectors....because most of the time you need a chip or a ecu upgrade to tell the injectors to open up more...if anyone could help me out on this that would be awesome..
thanks
BATES
thanks
BATES
From my understanding installing, larger injectors would not work. With the pulley upgrade you also get a fuel regulator. The regulator combined with the software change act as if you installed bigger injectors. Dinan uses the factory injectors with modified software. By stabilizing the fuel rate (volume)and incresing the time that the injectors stays open allows for an increase in fuel. I think it is a different way of increaseing the fuel rate without changing the injectors.
well the only problem is that i am not running there boost kit...which includes the regulator and fuel pump....
BATES
BATES
I have the JCW Injectors
I don't know if they make a difference as far as power is concerned, but they don't seem to cause any problems. I have the boost kit, DINAN stage 5 software, JCW injectors, throttle body, and CAI.
I would say barely noticeable normally, but just a bit more oomph when approaching the 7300 RPM redline...
Originally Posted by d6-mcs
cool at least someone else has somewhat info i needed to know..thank you....did the injectors help at all..
BATES
BATES
minimofo
Apr 4, 2016 07:36 PM
