R50/53 The gearbox does not shift.
Old May 22, 2023 | 11:58 AM
Martin715's Avatar
Martin715
Hey. Can you help me with my Mini Cooper?
The gearbox works very strange. It shifts to 2nd gear, but does not turn on 3rd, and on the tachometer the arrow goes off scale for 3000. Is this gearbox gone? Or could there be something else?
Old May 22, 2023 | 12:26 PM
Cable end came off above the transmission or under the tunnel shifter. Most of the time the end link pops off the end of the cable above the transmission Check that first. .
https://www.northamericanmotoring.co...-advise-3.html
Old May 22, 2023 | 12:30 PM
Fradow's Avatar
Fradow
Which year/model is it?
No matter which it is though, first step is to take off battery / air box (depending on year/model) and inspect the shifter linkage. Have someone go through the gears and see if the linkage properly engage all gears on the gearbox itself. Most probably, the linkage needs replacement, which is a lot faster and cheaper than changing a gearbox.
MCS4FUN's Avatar
MCS4FUN
That being your first NAM post, welcome to the forum...
What model year and build date (check VIN plate under the bonnet)? If mid-year 2004 or older, might well be the shifter cables are shot. After that date (running change I believe), improved design for cables and shifter box assy. If yours is the earlier version and cause of your shifting woes, you'll need to replace both the cables and shifter box to the later style. New OEM parts are still available (but not as complete assy), however buying a used combo would be prudent instead. AllMag has one from a donor R53/R52 listed for $300. Watch forum member Mod Mini's tutorial video and see if that helps determine. IMO, much better that than the Getrag gearbox...
Old May 22, 2023 | 12:31 PM
Martin715's Avatar
Martin715
I didn't specify, sorry. I have an automatic transmission.
Old May 22, 2023 | 12:32 PM
Martin715's Avatar
Martin715
Old May 22, 2023 | 12:34 PM
Oh, thats a transmission gear issues/shift problem. Something internal that 3rd is most likely gone. You would have to take it to a transmission shop to further diagnosis or MINI. Lots of the internals are not on its own and i believe that a flush is not going to fix that. Its a Aisin 6 speed transmission made for MINI. Very similar to the VW one but not exactly the same.
Maybe a solenoid went bad and you would be lucky, maybe valve body and something is clogged/stuck?
https://www.northamericanmotoring.co...y-rebuild.html
Old May 22, 2023 | 12:38 PM
Martin715's Avatar
Martin715
I have an automatic transmission. Maybe someone else knows something?
Old May 22, 2023 | 12:39 PM
Just posted above.
Old May 22, 2023 | 12:40 PM
Martin715's Avatar
Martin715
Just posted above.
Yes, but is this the only option?
Old May 22, 2023 | 12:46 PM
Yes, its really had to tell. Some people do a flush if they have hard shift, this is completely missing a gear out of 3rd and revving out. Some people do a flush but cant bet thats going to work.
Check this out below.
https://www.northamericanmotoring.co...over-revs.html
Old May 23, 2023 | 11:08 AM
Martin715's Avatar
Martin715
Hey! I think it's the solenoids.
sungjk
Jun 16, 2019 05:28 PM
crazyworld
Oct 15, 2014 02:56 PM
k.marcoe
Sep 19, 2009 09:09 AM
megmini5
Jan 17, 2008 09:48 AM
