R56 Anyone have any info on a GA6F21WA tranny rebuild??
Old Dec 10, 2019 | 04:13 PM
Missfire's Avatar
Missfire
I have been studying how these automatics are built for the last week before tackling this job and come to realize my cooper s has a GA6F21WA not an 09g...fml😓. I cant seem to find any videos or detailed write ups on a rebuild of this tranny. Now many of you might say just buy a used one since itll be roughly the same price but for the same price I'd like to rebuild it myself knowing I won't have slipping clutches or valve body issues again with a used trans. Not going to pay top dollar for a reman one. Anybody got any info/diys? Upon further inspection it seems it's not too diff of a design than an 09g. Is this the case or am I just imagining. Thanks.
Old Dec 11, 2019 | 05:48 AM
MiniToBe's Avatar
MiniToBe
when I was playing with my '13 justa transmission, I relied on the 09G videos. There is a guy on you tube that goes through them in a great detail, even though he uses a VW tranny version.
Old Dec 11, 2019 | 07:07 AM
Missfire's Avatar
Missfire
Great. So they are somewhat similar internally. If you don't mind me asking which rebuild kit did you use for the GA6F21WA. Im only really seeing this wolfsburgtuning brand offerred in a master kit but not sure on its quality/ reliability. Thanks.
Old Dec 11, 2019 | 07:12 AM
MiniToBe's Avatar
MiniToBe
Weeeelll...I stopped short of doing that. I bought the car as flood recovery and after 900 miles of driving, the transmission gave up. I took it apart and couldn't see anything out of the ordinary. Mind you back then I was still learning about minis so when i was filling the ATF, I would put like 7 quarts while the car was off...i was a novice lol. Anywho. I'm sure these repair kits are shared with vw. The clutch pack might be fine and in most cases it is the valve body. I think for now, you could check the clearances and solenoids resistances.
Old Dec 11, 2019 | 04:55 PM
Missfire's Avatar
Missfire
Gotcha. Well it could be the vb as well so will def be checking that. I bought the car with the slipping trans so it seems they've been riding it like that for quite some time. There are other symptoms indicating worn clutch packs as well. Weird that there's so many videos diys for the 09g but nothing for the f21. 🤔
Old Dec 12, 2019 | 06:55 AM
MiniToBe's Avatar
MiniToBe
I think when these transmissions change name when they're used with different auto manufacturers. Here is a link to a very similar transmission https://www.automaticchoice.com/en/t...sn-09g-09k-09m. I know ours does NOT have a gasket on the ATF pump. I also remember when I was messing with one VB, one or two of the check ***** where stuck. So, before messing with the unit itself, try the VB rebuilding. I had a thread here somewhere and even there was another person who had similar issue. In his case, there was a worn out seal or something in the clutch pack.
check these links:
https://www.northamericanmotoring.co...-pressure.html
https://www.northamericanmotoring.co...tic-parts.html
Old Dec 12, 2019 | 07:16 PM
Missfire's Avatar
Missfire
check these links:
https://www.youtube.com/watch?v=lTGQ...ture=emb_title
thanks for the info. Yeh my plan was to use a transgo solenoid repair kit and clean out the vb at the same time. Because I'm repairing this car for my mother who loves minis I just want to do it right once and not have to think about it again in the future which prob means replacing all frictions/ steels and replacing the drum seals and molded pistons at the same time with the master kit. Guy before me blew his n14 so he put in a reman one right before I bought it. I'll def check out those links thanks.
Old Dec 22, 2020 | 05:44 PM
Scott Charlton's Avatar
Scott Charlton
Sent you a PM.
shaunx
May 27, 2022 09:02 AM
jmedina94
Nov 11, 2016 03:12 PM
EddiK
Aug 15, 2016 04:30 AM
taffyc
Feb 6, 2015 11:46 AM
sharkie104
Cooper (non S)
Jan 24, 2012 06:05 PM
