R55 Need help finding a wiring harness for the coils
Old Jan 25, 2023 | 12:57 PM
angeln562's Avatar
angeln562
I was driving home today and the sound dampening mat under the hood came loose and inched it's way onto my turbo unit and caught fire. It melted the wiring leading to the ignition coils along with the coil packs and also burned a hole in my valve cover. Does anyone know if the wiring coming from the coils to the coil packs is sold separately or do I have to buy an entire ignition wiring loom? Any help would be greatly appreciated.
Old Jan 25, 2023 | 01:57 PM
Here you go, up to 9/2009 N14 Engines: https://www.ecstuning.com/Search/Sit...h/12517567114/
9/2009 - 3/2010 N14 Engines https://www.ecstuning.com/b-genuine-...s/12517585952/
3/2010+ N14 Engines: https://www.ecstuning.com/b-genuine-...s/12517646453/
No other part sold on that harness. Only other way is to rewire the bad parts. Do you have an 2009-2010 R55 S N14 Engine?
Old Jan 25, 2023 | 02:24 PM
angeln562's Avatar
angeln562
It's a 2008 S.
Old Jan 26, 2023 | 06:30 AM
ok then its that top one.
Old Jan 26, 2023 | 11:26 AM
angeln562's Avatar
angeln562
Thank you. Looks like my weekend just got more expensive and busier.
Old Jan 26, 2023 | 12:30 PM
Only other options is to have someone or yourself rewire and wrap.
Thats the tape they wrap with after the wires are all connected and soilder/sealed : https://www.ecstuning.com/b-genuine-...m/61136920760/
Old Jan 26, 2023 | 01:12 PM
angeln562's Avatar
angeln562
That could be an option if the shielding did not bake off completely.
Old Jan 27, 2023 | 07:16 AM
Yikes, sorry to see that. Yea you are going to need a harness, valve cover, coil packs. etc..
Replace that sound dampening and get new clips. https://www.northamericanmotoring.co...ay-or-nay.html
All i could think is turn it into the insurance, that's what i did when the mouse chewed my wires.
Old Jan 27, 2023 | 09:34 AM
angeln562's Avatar
angeln562
That would work if had full coverage, but give me a nice project for the next couple days. Thanks for the suggestions.
Old Jan 27, 2023 | 10:05 AM
You are welcome, glad to help.
Old Jan 28, 2023 | 07:49 PM
angeln562's Avatar
angeln562
Almost there. Just waiting on the coil wire replacement
Old Jan 30, 2023 | 08:49 AM
Get a metal tin cover on that also, that bolts to the front over the turbo. Unless you already have it.
Old Jan 30, 2023 | 09:00 AM
angeln562's Avatar
angeln562
I got the CTS Turbo one. It should arrive today
Old Jan 30, 2023 | 09:25 AM
I would run that and the factory metal tin one. CTS - Thats just an extra layer. That turbo can get hot and i don't want you to have problem.
Old Jan 30, 2023 | 10:27 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
What he said. The CTS turbo shield will not protect the valve cover and wire harness as well as the OEM shield. Even though the OEM shield looks like crap, it provides the best barrier between the turbo and the valve cover and harness.
Old Jan 30, 2023 | 11:27 AM
angeln562's Avatar
angeln562
Thanks guys, I will need to get the factory one as well. When I bought the car it had no shield because the original owner put a bigger turbo than the factory one. Rather than put in an appropriate shield they opted to use none. I added the DEI exhaust wrap this weekend to give it additional protection.
Old Feb 16, 2023 | 01:36 PM
angeln562's Avatar
angeln562
Back on the road. Now I need to figure out where this oil leak running to the oil pan is coming from. With my luck I'm 99.99% sure it's coming from the turbo feed line.
4mikebruns
Mar 10, 2018 04:43 PM
benben01
Dec 14, 2017 06:31 PM
TheRedFalcon
Sep 30, 2013 05:13 AM
brutalsun
Feb 1, 2008 11:03 PM
MSFITOY
Electrical
Aug 17, 2007 06:36 PM
