R50/53 3rd brake light on all the time
Old Jul 16, 2021 | 10:16 AM
ssoliman's Avatar
ssoliman
Hi mini owners. My 3rd brake light stays on. I was able to pull fuse 20. That put it out but it’s the fuse for the fuel pump as well. So…
maybe (probably) related. Got some water (less then a gallon) in the left side floor board in a rain storm just before I noticed this issue.
Looking for ideas on how to troubleshoot this from here
Old Jul 17, 2021 | 08:21 AM
ssoliman's Avatar
ssoliman
found this tread (below)
seems to be related to the water and a diode under the bcm. going to open up the carpet and have a look and try and dry everything. will report back
https://www.northamericanmotoring.co...s-stay-on.html
Old Jul 18, 2021 | 05:58 AM
ssoliman's Avatar
ssoliman
Removed the seat.
Removed the panel on the side of the door sill. That’s held in by one large torx bolt in the back holding the seat belt down. After that it pulls straight out towards the middle of interior, has clips.
Propped the carpet up with some small wood pieces I had around.
Put fan on it.
Old Jul 18, 2021 | 05:59 AM
ssoliman's Avatar
ssoliman
Old Jul 18, 2021 | 03:01 PM
ghostwrench's Avatar
ghostwrench
I noticed one evening this past winter that my 3rd brake light was on with my foot off the brake pedal when my headlights were on. Further investigation found my right brake light bulb was out. When I replaced that bulb, the 3rd brake light started working properly.
Old Jul 18, 2021 | 03:53 PM
ssoliman's Avatar
ssoliman
had not even considered that. I will check this
Old Jul 18, 2021 | 03:55 PM
ssoliman's Avatar
ssoliman
Got everything dried out and back together. No more issue with the third brake light on for now.
I'm going to check the other brake lights and see if they are good.
Old Jul 19, 2021 | 05:51 PM
ssoliman's Avatar
ssoliman
Was able to check all break lights today. All good. 🤞
Old Jul 22, 2021 | 08:32 AM
SkiahMutt's Avatar
SkiahMutt
Out of curiosity, did the water get into your car because you left a window down or sunroof open? Or do you have a leak? On my first R53, my sunroof drains were clogged, and any time the car saw rain, I'd end up with water inside the car. They were fairly easy to unplug, if you've got a sunroof I'd advise at least checking them. Cheap and easy insurance against having to deal with this again or even the potential for worse damage.
Old Jul 23, 2021 | 02:51 PM
ssoliman's Avatar
ssoliman
this was high ground water near the curb on the street…
no sun roof on mine but I have seen many complain about the sunroof drains so point well taken
Old Jul 26, 2021 | 11:11 AM
USNAE2's Avatar
USNAE2
Veteran: Navy
Mine was the A/C Drain the drains under the car was clogged (somewhat common I guess). So, with the A/C on it would eventually fill the passenger Foot/Seatwell and even went into the back seat section. Took 3x to get it fixed. It was a PAIN but, hasn't been a problem in over 3 years and I do run the A/C occasionally. No sunroof either.
Old Jul 26, 2021 | 11:57 PM
ssoliman's Avatar
ssoliman
yes heard of that as well. And also the heater core connections leaking...but that would be on the drivers side (left side). Anyway good to hear you got it
MC2005s
May 1, 2014 09:33 AM
juchong
Electrical
Apr 23, 2011 08:57 AM
michele r53
Nov 27, 2010 12:37 AM
jwmckenna_pi
Feb 2, 2006 03:11 AM
