R50/53 Trickle Charging
Old Oct 28, 2020 | 01:45 PM
Jonny's Avatar
Jonny
Trickle Charging
Is it sufficient to connect a trickle charger to the remote terminals in the engine bay, as opposed to directly to the battery in the boot, for winter storage. Does it make any difference? Obviously for an S with battery in boot lol.
Old Oct 28, 2020 | 02:08 PM
RB-MINI's Avatar
RB-MINI
Not sure if it’s for a technical reason or convenience, but the owners manual says to use the under hood + post for jump starting and charging on a 1st gen S.
Old Oct 28, 2020 | 02:51 PM
steve05ram360's Avatar
steve05ram360
No, will be fine. the only thing to keep in mind is the cable resistance back to the battery, your source current should be high enough to provide enough to keep it fresh.
FWIW, I rebuilt a new to me shed, had no power and decided to use an old car battery with a VW solar charger to supply power to LED lights I am putting up. Put the charger in the garage window hooked up to the battery and it supported 12.3~12.5V fine w/o a load. I then hooked up 2 of the LED's full time to see how long it would drain, over several days it did start to dip down into the 12.1 range. In my app, will have the lights on for up to 30 minutes thru a wall timer.
Old Oct 29, 2020 | 02:41 PM
ssoliman's Avatar
ssoliman
Battery don’t care 🙂
Old Oct 29, 2020 | 05:58 PM
JB R53's Avatar
JB R53
I use the engine bay terminals - no problem.
CapWKidd
Feb 20, 2011 07:14 PM
wang3r
Oct 18, 2010 07:11 PM
Sylens
Dec 25, 2007 05:46 PM
Thadeus13
Jun 14, 2005 02:15 PM
Redleg13
May 4, 2005 04:49 AM
