They did come with load resistors already installed.
I'm probably going to ditch the self stick tape and screw them to the sheet metal for additional heat dissipation.
I also installed blacked out LED side marker lights, [the ones that flash with the turn signals] but have the original front lights, [turn signals]
Blacked out LED
After I had the hyper flash issue, I removed the LED from the sidelight and replaced them with original, [non-LED] bulbs and the hyper flash went away, so obviously these were the issue and I assume they need a load resister as well.
My issue is I'm not sure a load resister would fit in the are where the side marker is. I mean I guess I could push one in there but I don't think I could attach it to anything. Is it ok that it just "dangles"?
Has anyone dealt with this differenty?
So to follow up. I bought a 4 pack of Load Resistors off Amazon for like 8-9 dollars.
Took the side marker lens and the "S" emblem out. then took the washer bottle out of the drivers side foe access to the wiring for the light. . Then stared at things a while trying to figure out how to wire this up, [I mean I knew how to wire it up], just not where the Load Resister would go so I could mount it directly to metal for the heat sink properties. [reportedly they get really hot]
After staring at things for about 5 minutes and finishing the other half of my beer I said screw it... The LEDs are cool and all but just not worth the aggravation of the installation.
If anyone wants the ones I bought for like 10 bucks [less than 1/2 price] and the cost of shipping, let me know. First come first served. Hell, I'll even throw in 2 load resisters.
As the OEM lenses were a little foggy and I actually broke one getting them apart, [or more accurately it fell apart] I bought these;
Described as; Unique Euro Light Frosted Smoke Lens! Smoke lens is not painted on or tinted on, it is made that way. Therefore, it will not fade.
In my opinion, close enough.
