F55/F56 2015 MCS with LED headlights. Replacing bulbs with LED for breaks and rear turn s.
Old Jun 4, 2019 | 06:02 PM
cub4bearindiana's Avatar
cub4bearindiana
Hi everyone..
I got Bimmercode and adapter. I was able replace so far side markers bulbs to LED. Also replaced rear turn signals to LED, and finally those two break signals bulbs to LED. And there is the problem.. After doing the breaks bulbs to LED, I only get the bottom half to light up, without the top portion.
I did all the coding in Bimmercode and the upper LEDs are in good working condition (checked)... I cant figure out why the upped half won't light up with breaks being applied?
Forgot that I also activated my rear fog lights (no switch in dashboard) as my additional break lights
the part which is not lightning up is marked in blue circle
Old Jun 4, 2019 | 07:07 PM
N0B0DY's Avatar
N0B0DY
Remove the fog lights as brakes and they top brake lights should work again. I had the same issue.
Old Jun 4, 2019 | 07:33 PM
cub4bearindiana
So I am guessing there is no way around it? Not even in expert mode?
Old Jun 5, 2019 | 07:38 PM
N0B0DY's Avatar
N0B0DY
Some people have done it successfully but I haven't been able to get it to function with both the top and bottom brake lights.
Old Jun 5, 2019 | 09:26 PM
TVPostSound's Avatar
TVPostSound
Get the switch, use the rear fogs as intended.
It really freaks people out when turning on in inclimate weather!!!
FIY, If you video yourself panic stopping, you can see that your turn signals become brake lamps.
eebdel
R59 :: Roadster Talk (2012+)
Aug 28, 2021 09:35 AM
M.AC28
Mar 26, 2019 10:42 AM
ljmattox
Electrical
May 14, 2012 05:34 PM
preme123
Apr 9, 2012 12:09 PM
Axion
Factory JCW Talk (2009+)
Nov 27, 2011 05:15 PM
