R60 All aluminum radiator option
So after looking at the radiators offered in FCP euro I see an all aluminum radiator option for my 2012 R60.. if I currently have the radiator with the composite ends but want to switch to the all aluminum radiator will I need bracket extensions to be able to mount it?
Hello,
https://www.ecstuning.com/Mini-2012-...ling/Radiator/
Do you have a Countryman S ALL4 ? The factory ones are all metal?
If you need anything let me know.
Mine is not the All 4 model.. so I'm going to say it won't be a bad idea to put the all aluminum one in though.. and I've noticed a "buzzing" like sound from what seems like the aux water pump area after I turn the car off. I release the pressure from via the expansion tank and it fades away.. so if I read certain posts people were saying it's a sign that the boost solenoid valve is starting to go.. ??
Hello, So you just have the S model? They are all metal also. Just watch for the auto vs the manual versions.
That buzzing noise if you a have an S is from the aux water pump that turns on after you shut the car down. Its normal.
https://www.northamericanmotoring.co...placement.html
Buzzing from the front is usually the aux pump. Did you check it below.
When its the aux pump is on the pump itself and you can hear it: https://www.northamericanmotoring.co...ng-engine.html
On the kazoo noise from that unit its this 11657599547 : https://www.northamericanmotoring.co...ing-off-2.html
https://www.ecstuning.com/Mini-2011-...Turbocharger/5
Pressure converter
Pressure converter
