R50/53 Fumoto Oil Drain Valve- Think this will work??
Old Nov 1, 2019 | 05:18 PM
RudeJoe's Avatar
RudeJoe
I just installed a Fumoto drain valve on my Mini and I'm worried that its hanging down too far. Its just a 1/2" or so below the oil pan but seems like a long way. I put one on another car recently and it tightened down in a similar orientation. Valve lever is also down. Frustrating.
Anyone else installed one and it ended up in this orientation?
Old Nov 2, 2019 | 11:14 AM
ssoliman's Avatar
ssoliman
Does it stick out past the bottom of the pan?
Old Nov 2, 2019 | 02:06 PM
ItsmeWayne's Avatar
ItsmeWayne
Quite a few are used here! I don't have one though.
Old Nov 3, 2019 | 01:55 AM
Rah's Avatar
Rah
Just installed mine a couple of weeks ago, it is facing down and a little lower then the oil pan yes, but not in the way of anything in my opinion? the shield underneath the car is lower then the lowest part of the oil drain.
Old Nov 3, 2019 | 08:56 AM
ssoliman's Avatar
ssoliman
I’d say it’d most likely not be an issue. Just lookout for road hazards...but that’s the same for all cars.
whats the benefit here? Easier oil changes?
Old Nov 3, 2019 | 08:55 PM
Rah's Avatar
Rah
Yes easier and you can run a clear tube to the plug to run the oil to whatever container since the oil filter is accessible from the top
Old Nov 4, 2019 | 09:40 AM
HaltCatchFire's Avatar
HaltCatchFire
Mine points straight down as well. I'm not too worried about it since as Rah said it's not actually the lowest point in the car. If you hit this you will be high centering your car anyway. Worth the risk I'd say - oil change is now sooo easy, just run the hose straight into a jug and flip the valve!
Old Nov 4, 2019 | 11:18 AM
Thinker2112's Avatar
Thinker2112
I had one on my R50 for more than a year in that very position. No issues at all. Mine didn't even come with the clip to hold the tab in place and still no issues. My R53, the tab is pointing straight up. A little harder to use, but still no issues there either.
speedman
28
Apr 18, 2020 06:30 AM
scatpack
Dec 20, 2010 05:17 PM
yellowbritishrocket
Jun 14, 2008 04:02 AM
cpayne
15
Jul 23, 2007 07:07 PM
Darxar
Jan 21, 2004 11:41 PM
